  • Replies 154
y0 craved, my engine mount for the CA18 seems to be showin some stress due to engine twist. My fault I guess for doin some ghetto welds ;) How much is the full engine and gearbox mount kit from where you got it?
ok, the brother of the owner and i created a new one for the passenger side, the easiest thing i could suggest you could do is to create a JIG from your existing one including templates for the end plates, hole locations etc
this would allow you to get these done extremely cheaply. and be easier than us designing them for you since we are using engine mounts from a jap spec corrolla (dont ask - they were already on it)
take the JIG and the existing ones to an engineer, this would allow them to ceate them without having to work it all out, hence they just cut the steel and welding it for you.. would be stronger and the they wouldn't have to spend much time creating them. which will make it cheaper. take most of the labour out of the equation.
the gearbox mount was simply a standard gearbox mount with the centre modified and a reinforcement plate welded to it to align with the mounting holes on the ca18 box ... not too much work involved, although the gearbox and everything is back in the car so i cant get photos for you.
we have welded the new rear quater skirts and tailgate back on to remove the rust, the modified lower control arms have been lengthened and reinforced .. they are bolted back in , just waiting on the new custom sway bars to arrive. adjustable strut tops are in place.. just have to find a shock setup to allow a high level of lowering while maintaining a wide range of motion before bottoming out.
can you confirm if the front suspension of an MR2 is usable on these?
oh and use a higher grade of steel on the engine mounts.. what rubbers are you using? try and find something that has a harder compound.. as ours are a bit soft to cope with the ca18's power/torque movements.
  • 5 months later...
hows your Project going Shan ??
considering buying one myself as a daily driver...
the one we have been working on has just been prepped for respray.... welll its been primed and waiting for the sanding back... then spray..
should be going candy red for it, i just wish the owner would get a body kit for it before it gets sprayed.
you know anywhere to gets kits for em?
not as fast as I'd hoped unfortunately... the engine will be put in sometime this month. I've been fixing up the little niggles and stuff on the R32, coz I'm looking at selling it soon, so the AE86 has sat in the back of the workshop for the last couple of months gathering dust.
Me n inark are dabbling in some fiberglassing so we can make our own custom kits, but at this rate it might take us over a year :(
CA18DET, with CA18 gearbox, T18 diff and TRD 2 way LSD. Ended up deciding to try and adapt the S13 engine crossmember to fit onto the AE86 chassis, and at the same time mounting the S13 power steering and steering column in rather than using the less than inspirational toyota one.
sounds like a little extra work with the S13 crossmember... but atleast then you would be able to use the STD. engine mounts.
whats mods you have to do to use the steering column through the AE's firewall??
dunno, will let you know when we get around to it :mellow: still trying to fit the cross member and make the suspension fit.
Worked out easier tho, all I had to get was an S13 cradle without engine, and got all the parts. Also means I'll get to use standard S13 bolt on suspension parts and have a smaller steering wheel lock.... and power steering :)
drifting was on Foxtel on inside speed. Yellow 86 would be crab methinks.
and yessir... that would be my 9 piece BN Sports Widebody kit being test fitted. 50mm on either side. The wheels on the car are stock silvia ones.
siiiif I'd waste my time on an S13 (the AE86's gettin most of the S13 parts anyways). Besides, with all the kids running around in widebody S13's S14's and S15's I need something different.
Its for my R32, and no it'll be done sooner than 2 years, maybe next year or something. lol I cbf.
Here's the finished product on a car in JP.
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
