Hey guys, upon searching for a car that i really like i happened to come across the skyline. It's always been nice looking, quick and hoT.
I would like to purchase an R33 GTS25t and am on my P's.
Down here in melbourne i've managed to gather this:
Kw must be under 125 per tonne.
engine capacity to weight ratio not over 3.5 litres per tonne.
Now im not sure of the weight of the R33 - could someone plase tell me the exact weight that i'd have to divide by in order to work it out?
And also since it's 2.5 i think i'm safe there...
so i just need the weight - MUCH appreciated
Thanks.
https://www.sau.com.au/forums/topic/54559-help-with-p-plater-and-r33-gtst/
I think its OK.
If its ratio is 2 high, then i dont think the cops really care.
I've driven r33 GTSTs past them often, even been pulled over
a lot, power to weight ratio didnt even come up.
I hear they're becoming more strict now, since that black
Skyline crashed a few weeks back.
If you want to live long enough to get your full licence DONT buy a skyline on your P's
YOU WILL DIE or KILL SOMEONE!!!!
i did stupid things when i was on my P's like most of us do, and the only reason i am here to talk about it, is because i had a 1978 datsun (skyline GL). The idea of P plates is to get experience driving, before you start driving a powerful car. I still managed to spin the datsun and get into scary situations that i know for a fact i would not have been able to get out of if i had my R33. Especially in the wet, take the example of the p plater who killed his 2 friends on Dandy Rd a few weeks ago.... he lost it on a gentle left hander and slid for 100m before slamming into a pole!!!! The only reason this happened was because the car was too powerful and he didnt have the experience to know that foot to the floor in the wet is not possible!!!!!!!
At the end of the day its your money and your decision, its up to you whether you get one or not.
EDIT: An R33 weighs something like 1360kg IIRC, and makes 185kw. Use a calculator to work out the kw/tonne ratio.
Dam... i think it comes out to be 136kw per tonne..
Which is over 125 per tonne...
Maybe i should hold out until im off my P;s :D
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
