Bonnet $320
Both Front Guards $250
Doors Complete $200 Each
Steering Wheel With Airbag $180 on hold SOLD
Instrument Cluster 70 000kms $120
Front Lights $250 A Set SOLD
Rear Lights $250 A Set
Exhaust Midas Special Cat Back SOLD
Boot Lid And Rear Wing $350
Ac Condensor SOLD
Ac Compressor $100
Altenator $200
radiator and shroud $180
Diff perfect cond $250
Half shafts $150 for both
SYDNEY ONLY PLEASE
Most Parts Still Available
Pm For More Info Or Can Contact On 0403392718
Prices Negotiable!
https://www.sau.com.au/forums/topic/54616-r33-gtst-series-1-various-parts/
  • 3 weeks later...
