Ive got a suplier who is willing to sell me ten 49cc mini bikes for $440 landed here in adelaide.
specs are; 49cc
Bore 44mm
Stroke 32mm
Fuel tank 1L two stroke 25:1 fuel oil mixture
Top speed 75 KPH with max 110kg load
Max power 2KW
Max Torque 2.4 NM @8000rpm
Both front and rear sprocket can be changed for hugher top speed or better accel.
AFTER interest at this stage money will need to be paid upfront to me, if the first ten go, can order more
colours are; Blue, Red, Green, Black and yellow. no more of the crome pictured
thanks Matt
https://www.sau.com.au/forums/topic/54732-eoi-49cc-mini-bikes/
  • Replies 52
yeah ill see what i can come up with. you can now get a permit to ride them on linear park and places like that too.
Im not trying to palm them off, im accually getting one myself and I wouldnt sell anything I wouldnt use or have myself
    • How many of you guys run the synchro os giken set and at what power? Do you then also use the billet plate?  How is it launching with it, any dragy times from 0-60? 60ft?
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
