Welcome dude,
Getting to 200 isnt a huge ask, but will probably cost you a few bucks. Depends on whether you go second hand gear or new, either way keep your eyes open, ask around and be patient and you could save some decent dollars. A good place to start is with the forums, as they have the for sale section - also keep an eye on the popular mags as sometimes businesses will pump out some really good specials. Lastly, do a bit of research before spending your dollars and you'll be buying the right peice of kit at the right price.
For 200rwkw, a suggestion would be:
exhaust system
Pod Filter
Front Mount Intercooler
Electronic Boost controller or a bleed valve, and
Super Air Flow Converter (SAFC) or similar
Also don't look over your clutch and suspension, with extra power you will need to get it to the ground:)
This should get you close to 200 or maybe a bit over I think, what do the rest of you guys recon?
Steve
https://www.sau.com.au/forums/topic/5495-200rwkw/#findComment-83775
I would say those mods aren't quite enough to get to 200. Maybe 180-190. For 200 I'd say you need this.
FMIC
Full engine management (A SAFC isn't enough I reckon)
Full exhaust
14psi boost or so (preferably an EBC)
Boxed pod filter with CAI
I'm not so sure on the fuel pump. From what I've heard you should be ok at 200rwkw. Any more and you'll want one.
You could also go for an adjustable cam gear to fatten up your curve. I have a dyno graph from a supra with the gears and it made a huge difference.
Also, you have to remember all dynos are different.
Cheers,
Michael
https://www.sau.com.au/forums/topic/5495-200rwkw/#findComment-84092
The limit of the standard turbo is around 180rwkw. Some will make a little more power, some less...
If someone has proof that a stock turbo made 200rwkw+, all it means is that it was dyno'ed on a "happy dyno"...
https://www.sau.com.au/forums/topic/5495-200rwkw/#findComment-84094
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
