Cops know - everyone is innocent :(
But yes. It would be interesting Reidles - especially if you have insight into the HWP operations. As I understand it (and as most laws) there's the law of the police and law of the lawyer. So sometimes what goes down on the street isn't always right and if you have the money can be thrown out at court.
On the other hand I'm sure alot goes down in court that wouldn't be brought up on the street either.
https://www.sau.com.au/forums/topic/55112-cops/page/3/#findComment-1131790
  • Replies 56
I got pulled over by a speed camera operator before...and lectured about my speed, but he said he couldn't prove anything cause he was on his own? Good admission!
But I did point out the fact; the reason I overtook him, at what appeared to be a great speed, was because he swung out of a side street and cut me off on the main road and I didn't feel like plowing into him.
https://www.sau.com.au/forums/topic/55112-cops/page/3/#findComment-1131824
I only have insight for some operations and rbt locations for my area only. But wouldn't be in my best interests to tell everybody because that would defeat the purpose. Of course if i come across or hear of a major defect operation for example i will post a message to warn everybody, even though i am immune to it, because i know how annoying a defect can be.
For all your info i can possibly assist with things in the Hurstville, Blakehurst, Beverly Hills, Kingsgrove, M5 East from Beverly Hills towards city, Princes Hwy towards cronnulla from Kogarah and the general southern regions.
Cheers
https://www.sau.com.au/forums/topic/55112-cops/page/3/#findComment-1133215
gR33ddy as far as what you can and cant have, its completely up to you. Technically anything different from the stock specifications is classed as a defect. All mods should be ideally engineered to pass road regulations (But u wouldn't waste your time). Most police will look for the most obvious defectable parts on the engine ie. large turbo, fmic, chrome piping and BOV's. If you modify a vehicle try and do it with boltons that dont stick out and u will probably get away with it. Then again if you are really concerned about it, spend a fortune and get mods engineered and keep papers in the glovebox. This way you dont have a problem.
I have many obvious engine and vehicle modifications on my vehicle but unlike the rest of you, i dont get the pleasure of being hassled.
https://www.sau.com.au/forums/topic/55112-cops/page/3/#findComment-1145624
I believe a cop must follow you for 'x' km's before they can guesstimate you as speeding (I think X is about 100m, i'll ask mum this wkend when she comes home).
Ive heard something along the same lines. Is your mum a cop??
https://www.sau.com.au/forums/topic/55112-cops/page/3/#findComment-1146850
I was going down to the south coast for a holiday on monday and unfortunatly, this means going through liverpool which is a cop defect magnet.
Never had a cop ask about my car before, but as luck would have it, i got pulled over for rbt and then the cop told me to pull over because he was going to defect my exhaust. I was with another car load of people in a corolla and my car was full of bags and fishing reels etc. In the end, I think he realised that he wouldve ruined my holiday, so he told me he wasnt going to defect me, fined me $104 and told me to go put a silencer on it.
Sucks because i live opposite of a police station and they dont give a crap, but i guess its better than a defect. So my moral of the story is, im going to change the exhaust, pay the fine and never drive anywhere close to liverpool at all during holiday periods! :D
https://www.sau.com.au/forums/topic/55112-cops/page/3/#findComment-1149257
He basically heard the car at idle and said it was too loud. He fined me for 'insufficient silencing'.
I suppose i could dispute it because how would he know its too loud if it wasnt tested, but id rather just forget about it.
https://www.sau.com.au/forums/topic/55112-cops/page/3/#findComment-1152628
If you dont dispute it and try and clear your name then it will always be on your record.
Thats one of the reasons why I took the speeding fine to court. From now on I will always question my rights if police are trying to get me woth something.
https://www.sau.com.au/forums/topic/55112-cops/page/3/#findComment-1152835
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
    • I suppose it was relatively stock too, the JZ motor handle most mods thrown at them without even breaking a sweat
