  • Replies 91
CR ended up about .4 below standard so about 8.6.
Went with the ARGO rods and yes 256 poncams with matching springs.
Had Colin lloyd (Headsense) do the head work as well as machine and assemble the engine. Hopefully i can find the time to complete the rest at home with the help of my old man.
A break down of the costs involved with the engine build for those interested.
CP pistons $1185
Rings $275
Straighten & Polish Crank $182
Bore & hone block $188
Deck Block $110
Balance $ 267
Overhaul head $590
Porting $810
New guides $237
Cometic gasket $362
Big end bearings (ACL race) $89
Main bearing (King) $72
Gaskets etc. $28
Assembly $880
Total $5275
CP pistons $1185
Rings $275
Deck Block $110
Balance $ 267
Overhaul head $590
Porting $810
New guides $237
Cometic gasket $362
Gaskets etc. $28
Assembly $880
Total $5275
Thats a good price all up, where abouts did you get the work done?
Headsense (colin lloyd) at coopers plains. My only complaint with him was that it took a while before he got around to actually doing the work, he had my engine there for about 3 months. It's a one man workshop and he's pretty busy.
Yeah getting an engine built can test your patience, what made you choose him?
Does he have ALL the equipment to do the work on site?
Btw nice engine shot, looks really clean!
I went with him as previously i was getting most stuff done by Hardcore at slacks creek and i found out that he was the one that was doing all the headwork / machining for them so pretty much went straight to the source. He's pretty well known in drag racing circles and has been supercomp champion a few times now racing his own cars, you'll see his name across the top of the main stand at willowbank.
Putting the rest together and then putting it back in and hooking everything back up is the FUN part! Hooray. Then you will get it tuned and it will kill ya waiting to drive it. Leave the tuner in a nice cloud of white smoke all the way up the street....ohh such a good feeling when you got bulk power on tap :)
Cant wait till you post tuning results.
Still undecided with the tuning side of things. It will either be FIST performance or Mercury Motorsport. FIST have done all the work on my old mans XR6 turbo and they've looked after him very well but Mercury seem to have a better reputation around here.
I sent the plenum and rocker covers to be powder coated today. Have gone with gold for the rocker covers and textured black for them plenum. Pictures will be posted when i get them back. Hopefully they look ok.
powder coated hey. I know some people who hpc coat them...comes up pretty good. should look very nice.
Also mate, just wondering where did u find your v8 throttle body for the plenum. I could not for the life of me find one anywhere, and had to machine up an adapter plate to suit the std TB. Cheers.
Edited by r33_racer
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
