i have tried to get handbrake cables made before( not for a r30 tho) and had no success finding someone to do it...as soon as you mention its for brakes they dont wanna touch it.
i ended up findingone at a wreckers
i ended up finding one at a wreckers
a couple of wreckers told me to go to marine control cables in labrador, took it to them today said what it was "handbrake cable" and he said "off an old skyline i guess". he said he'd have a new one made by fri for me..
have you ever had to order something from nissan? i had to order a new clip for the shifter to hold it in place took 2 weeks to get here and cost $18, it takes time and is always expensive..
the lines are the same but hard to find. i throught i had a set waiting just to swap over but turns out the passenger side one was seized as the old calipar from my hatch was broken and just didnt work??? news to me...
hmm you must have an average nissan dealer then.
i ordered some bits off my local and the said we will call when they get in, to my surprise they were in 8am the next day!
oh and now my nextdoor neighbour works there so its even better!
Hey RSX84, would that be Von Bibra Nissan at Southport you're talking about? Never dealt with them personally, but they tried to rip off a friend of mine by telling her that her brakes needed replacing. She took the car there with a noise in the front end, and they said the discs are warped, and are too thin to machine, and pads were worn too. I had a look at them, and they were 0.5mm under new size (1.5mm of wear left) and the pads still had 9.5mm of material left on them.
She took the car back to one of their other yards on the gold coast, and they machined the discs for free. Car's good as gold now.
Anyway: I digress. I've usually never had a problem ordering stuff from Nissan dealers (except for the useless mob in Mount Isa, about 13 years ago). At times, they've supplied OEM parts cheaper than genereic aftermarket ones (eg timing belt for RB30)
The Adelaie Cable Company (23 Naweena Rd Regency Park 5010 (08) 8347 1944) will make custom cables. I've had brand new cables made for my Z and my dad has had new speedo & handbrake cables made for his 510 & SP310. The DR30 cables will be the same as the RMR30 hatch or MR30 Ti.
  • 4 months later...
hey sorry to dig up an old thread, but better to keep it going than start a new one on the same topic (cos ppl get told off for that :))...
I'm looking for 2 rear hand brake cables for my DR30. I highly doubt anyone knows any places in Perth but if there are any leads over east then that's great.
Thank you in advance.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
