  • Replies 416
haha yas yeah i know it camt out ages ago, i just haven't gone and looked at it lol :)
what is all this crap bout christian youth stuff? lol? and i'm with pete_pie who said anyone of us takes drugs.....? i think the christian lovers should have a can of "kiss my ass" coz sci fi is gonnna be massively huge :grouphug:
adrian :D
This is the most entertaining thread that's been in SAUWA in ages
It is full of whoring
has no relevance what so ever to skylines
But damn there should be more of it :) Thanks for making the last part of my day go faster.
Break it down now!
adrian :D
lol mosh pit
on saturday night i will be going around asking if people would like more information on christian youth centers so keep an eye out!
Dare you to carry around a sign "Jesus is coming - touch my bum and you'll be saved"
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
