heheh i jsut got the horse race schedule for Saturday:
Race 6: COMMENT NEWS COMMUNITY - JUNGLE MIST CLASSIC
I had to re-read it because the first time i read it - i read it like this:
Race 6: COMMENT NEWS COMMUNITY - JUNGLEIST CLASSIC
Can see where my mind is! :D
*petie - im pretty sure it does anyway .... its been a while since ive been there ... it sells a lot of rave type shirts and im pretty sure junglist was one of them. ;) Its on the main stretch .... on the metro's side of the road.
  • Replies 416
Hey does anyone have those like UV pens anymore ... you know the ones where you write on the skin and it only shows up in UV light. I was thinking about them the other day - havent seen them around since the last belmont gig that i went too.
i dunno if they will? for DnB.. but yeh.. ah well.. i know metros didnt use to ;) but ah well.. i have a UV one at home... i think its mikes? not sure.. i dun even know if it stil works.. but the good ole trusty yellow highlighters still work... might snatch a couple :D
I wish I had my car as my CD wallet is in there! I've been in this room making/painting sets for end of year concerts/performances all day and JJJ is gettin old on me!!
And bugger you IT guys for banning live-streaming dnb sites!
get to radio one...
try to find the adam freeland essential mix!!!
This has got to be one of the MOST AWESOME sets EVER!!! he even throws in rage against the machine!!!!! YEAH!
I have to go to sydney next week so i can't make it!! Guys pls if there is any advice i can give to you in my 5 years of managing and working in the clubs is that.. FERRY CORSTEN AND ADAM FREELAND WILL ROCK YOU!!!
Go hard guys, to my little SAU crew who i rocked with last time when hybrid was playing i will be rocking next to you guys in spirit in the adam freeland set!! if any of you guys have a sec can you please please please call me for a minute just so i can hear a quick mix of his!! i promise you he will be awesome!!
Man he better deliver otherwise i sound like a d*ck!!
blah after the day ive had :ak47: @ work ...... you have no idea how much im looking forward to this.
25GTT PM your number (i lost in the great phone stealing of 04) and i'll try to remember :)
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.   EDIT:  Not my channel but i saw this and i know that is what i want (and i have exactly this)
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
