Sounds like a fancy heading but not really :D
I just bought myself some DBA 4000 Slotted rotors and am trying to work out what brake pad will best suit the rotor
Driving style is generally pretty laid back eg cruising not much heavy braking but on the same token the reason why i got these is to obviously help pull me up them few meters that might save a few hundred $$$.
Does it actually matter what brake pad i get for them or are they all fairly unversal eg doesnt matter if its for slotted or standard...
options so far (without looking into it to much)
Bendix Ultimates (have heard they are dusty but most are)
race brakes now not sure exactly what sort but yea any particular recommendations.
Any advise would be appreciated
I think most people here run rb74 or something.
I've got some gtst m type brakes in my car and I just put in some project m d1 spec on the rear and ns (street type) on the front. They pull up ok but we'll see on the track. I think I should have got the nr or hc but they seem to be ok at the moment.
I don't think getting performance rotors/pads will help pull you up better all that much over stock items in good condition - they'll just mean the 40th time you go round the corner from 200kmh to 120kmh they won't "fade" and leave you looking at a wall or sand trap.
Either way good luck - if you're interested in the project m call andrew from mu's secret. They're import pads and make some good products and for some reason are still well priced against the aussie stuff.
Good luck with your brakes - I also think if you search out some braking threads they'll be people in the thread who specify that they use the same rotor as yours and what pad they use.
Hi Leigh, I have Bendix Ultimates in the road car with DBA slotted rotors and they are very good. No squeel, little dust, consistent stopping power and reasonable price. The race car uses Hawke Carbotics in the blue compound. They have a much higher coefficient of friction, so if the tyres are up to it, the car does stop in a shorter distance. They don't squeel, need a little heat in them, fair amount of dust, wear pretty quickly and the price makes my nose bleed. But the car stops in much shorter distances, the pedal is much easier to modulate, the tyres are up to it and it stops better for a whole 20 minute race.
Even in brake pads, you get nothing for nothing:cheers:
to true :D
i did a bith of a search and ultimates seem reasonable popular. i think the i might give the ultimates a go and see how they fair up :D
thanks for the feedback guys
Running RB74s in the GTR, still managed to give them a fair rodgering at Sandown. Glazed them I think...
Have previously run Endless NA-Ys in the GTSt at Sandown, pedal was still ok at the end.
Now have a set of Endless CC-Rs 'carbon ceramic metals' to go in... probably be noisy as hell... will report back
You might like to try Lucas pads from Gavsport in Sydney. Alternatively Ferodo 2500 is a good compromise. If you are a pretty laid back driver don't go for performance pads whatever you do, they just won't bite as much as organic hipo street ones will.
Has any body heard about "Green Stuff" Brake pads?? i heard that they are really good they retail for around for about $160 an end.
just heard of them and wanted to know if any one had any pro or cons about the "Green Stuff" product range
cheers..
Im using the RB74s, dont really have any probs with them.  Just sit on the brakes going down my street get a little heat in them, after that no worrys.  When they warm up however :)
Quoting my self is bad...
But anyway I thought I should just add, they are REALLLLLY dusty, just my wheels are brake dust colour to start with, so I dont notice it at all.
I have rb74's on the front with standard rotors and i have white wheels.
Well i used to have white wheels:
Apparently EBC as done a major reformulation on their Greenstuffs (now in version 4) to address issues such as rotor warping/scoring and glazing. Also all over the net, scooby guys are raving about their new pad, the Red Stuff Ceramics. (One rally guy said it was better than the DS2500s!) Might be worth looking into...
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
