I'm looking for a Trial R32 front bar. After being stuffed around by carmate for a month and a half and them sending the wrong bar. They have now told me they don't have any in stock.
Does anyone have one of these or a mould. If it's for a GTR no worries I can cut and modify easily.
https://www.sau.com.au/forums/topic/55614-r32-front-bar-trial/
$550ono
its brand new
never been fitted
i have actual pics if u interested
i paid $650 for it start of the year ($650 freight included)
Hay if you're willing I'll pay you $550 allup with delivery. I cost me $50 to get the bar from Sydney (though it was the wrong one) I can pay you as soon as Carmate return my cash, should be sometime this week or early next.
They cahrged you quite a bit. Carmeat were charging me $350 plus $50 for delivery but 2 months down the line I don't have the front bar I wanted so I'll pay the $200 difference.
Let me know
Kevin
sorry dude i gotta stick to the price i got mine from Bodyform in sydney
reason why it costed more was quality ( made in Aus )
whereas Carmate get most of there stuff from china
i bought a r34gtr bar of them earlier this year.. took 3 weeks and they also sent the wrong style. but im happy with the one they sent so i didnt complain
but when i called them up to say it was the wrong one they werent too happy about it
anyway at the moment i have someone interested in the bar and is happy with the price dude so first one with the $$ wins
$550 + freight
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
