slayer, I think you'll find this is a problem inherit with all R33 series 1 consoles and its probably the main reason (i hope) why people are painting their dashes. With age and possibly due to sunlight and armourall, the coating turns soft and gets really easy to scratch and peel. Its a flaw Nissan fixed with series II R33s by using a different (harder) coating.
My dash is going through the same peeling process, so I've also decided to paint it. Not rice boy red mind you (yes, I'm talking about YOU, G0DF4Th3R), but something really, really dark. I'm trying to source a place to do it for $150 or less atm, otherwise I'll follow EVL R33's DIY instructions.
https://www.sau.com.au/forums/topic/5569-dash-trim/#findComment-84491
Gradenko, is the series II dash physically different (eg shape and mounting points) ? If not, I could always try and source a series II dash section.
Hmm, I could go ricey and paint it I guess... but something like metallic charcoal finish.
Problem will be getting all the old armour all and 303 off the plastic so the paint actually bonds!
hmm, thanks for the info
Conrad
PVA Glue - I ALMOST have my car now!! :) Its in my driveway, but it has to go back tomorrow to be inspected for compliance... I dont think I will have it registered for the cruise on the 8th :(
https://www.sau.com.au/forums/topic/5569-dash-trim/#findComment-84496
S1 is a plastic with a rubbery type covering (what the hell is that? anyone tried taking it off?)
S2 has a more harder plastic and its rough, kinda grainy...
Its same but where the S1 hazards and stuff are it pops out a but hard to explain but if you saw it you would know wat i mean.
I had tried painting it in the my old line and BOTCHed it HARD!
then i got "professionals" to do it and they botched it even HARDER!!!
THats my experience,
DOnnie
https://www.sau.com.au/forums/topic/5569-dash-trim/#findComment-84630
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
