Hey guys,
1996 Series 2 R33
White
83000km
5 Speed
Apexi Power Intake
HKS Super Dragger exhaust from Turbo back
Slotted rotors front and rear
17" BLEST rims with dished rears...mmmmm
235's on the front and 255's on rear with good tread
KYB very low springs n shocks
Front and rear strut bars
VDO boost gauge
Nismo sideskirts
5% tint
Razo gear knob
Kenwood double din headnit
Pioneer 12"*2 Subs
300*4 Audioline amplifier
Oils, filters etc just been changed. Always has run stock boost.
This car today made 143.4rwk on...yes...6psi. SO a great start to ur modifying career.
9 or so months rego an will suplly rwc..VIC only
WILL consider trade with another highly modified car, maybe a cash adjustment from me depending on the car. prefer 32 or something similar
PRice is 21000 NEGOTIABLE
or
$20000 without the rwc.
https://www.sau.com.au/forums/topic/55816-1996-series-2-r33cheap-price/
you can p.m him, his nick is FLY-SKY, or find his for sale thread in the forsale section
i dont know your definition of high modded is, but i wouldnt call it any close to a stock r32.
let me know if u cant find his thread, ill send u details
thanks
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
