I was quite impressed with my back yard smell multiple rubber hose bolt clutch aligning tool.
It fits really tight. Much better than the tool that still has a little slop. :(
My backyard smell is looking at the bolts that I have left over and thinking WTF.. lol
yeah, I know the ones...they go in the shed so when you have the engine out next time you can say, "hey, that's where that bolt went". You either don't know where they go or they are too hard to get back in.
