I am looking for the centre caps off R30 15 inch alloys (the multispoked ones.) I only need 1 but I will take a set off your hands for the right price. They are a plastic chromed cap with the Skyline "s" in the centre.
I am also looking for a LH rear tailight (passenger side) but only if it is in immaculate condition as my current one only has a small crack.:)
Thanx in advance
I needed the hotplate lights.
Next question:
Does you car have a trim panel on the bootlid between the tailights? I might be interested in that. Maybe you could describe the panel to me and if sounds right take a photo?
Also looking for an instrument cluster surround.
BTW whereabouts are you located?
Thanx once again
RAVEN
Raven:
The trim panel on the bootlid is NOT the one with 'skyline' written across it. I beleive this is different to yours because this is a 4 door version.
The instrument cluster was available, not sure about the surround. I would have to check that as well. Are you interested in the instrument cluster itself, or just the surround?
Please feel free to email me on [email protected] with any further questions. You'll usually get a quick response during business hours.
cheers.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
