  • Replies 148
Originally posted by kabab
Yes but oh my god do they pull up !!
So whats a good brake pad / disc for a street car thats see light track work ??
What sort of pricing ?
Slotted rotors with Ferodo DS2500 pads.
https://www.sau.com.au/forums/topic/5677-disc-rotors/page/2/#findComment-86521
Just side tracking a little here Steve, I've got a question.
What brakes better, a 300mm disc with x surface area brake pad, or a disc with 333mm disc and same x surface area pad?
Also for better performance, would you make a bigger pad, or is bigger disc more effective?
https://www.sau.com.au/forums/topic/5677-disc-rotors/page/2/#findComment-87053
A larger diameter disc = greater brake torque
Larger disc mass = better heat capacity
Larger surface area pad = longer pad life
It depends on what improvements you are looking for.
https://www.sau.com.au/forums/topic/5677-disc-rotors/page/2/#findComment-87271
G'day all,
I had a similar problem with my 32 GTR. 4 hard laps
@ Wakefeild and my peddle went like a limp chicken!
:lol:
I'm was running Green Stuff up front and standards in
the rear (later I found that they were down to the steel)
I'm going up to wakefield again on Friday. so.....
I believe the brake fluid is what let me down?
I have put Kevlar's in the back and cleaned up my fronts!
Should I flush the brake system and go to DOT 5.1? or stick
with the DOT 4?
Steve, are these new rotors available to us humble aussies?
R,
Adrian
https://www.sau.com.au/forums/topic/5677-disc-rotors/page/2/#findComment-89625
Originally posted by GTRKING
G'day all,
:lol:
with the DOT 4?
R,
Adrian
Yes they are!
There will be a two piece version available soon too. Prototypes are sitting on my desk.
I would look into better pads too. Ferodo DS 2500 or DS 3000.
https://www.sau.com.au/forums/topic/5677-disc-rotors/page/2/#findComment-89693
Steve,,,I have your sloted and drilled discs on the front of my R33 GTS-T using Greens. The cars brakes are WAY better than standard. I'm as happy as a pig in shit!!!!.My problem is,,, I have been waiting for a set of sloted rears for ages now and I MEAN ages. Am I being stuffed around or are they actually available.
I'm not interested in trackwork by the way.
Neil.
https://www.sau.com.au/forums/topic/5677-disc-rotors/page/2/#findComment-90100
Neil.
The DBA 908 rear is available but we apparently dont keep enough stock. They are due to be cast again this week and hopfully be in stock at the end of the month.
https://www.sau.com.au/forums/topic/5677-disc-rotors/page/2/#findComment-90119
Originally posted by skyzerr33
so whats the part number for the slotted rotors front and back for a 94 gtst?
294 and 330mm?
will these suit for street driving and the odd motokhana when coupled with greenstuff or race gear pads?
We are still working on this one. We have found 3 different front rotors so far for this model.
1. 296mm x 32mm = DBA 926
2. 296mm x 30mm = ?
3. 310mm x 30mm = ?
We have samples but we have not alocated numbers to the last 2 yet. We need to confirm model specs for each part.
The rear is the DBA 908.
https://www.sau.com.au/forums/topic/5677-disc-rotors/page/2/#findComment-90370
Originally posted by Pva_Glue
Come on steve! You got my old pair of rotors!
so what's the part number for it heheh :P
cheers
Joe
70 new part numbers this year my friend and another 50 being assessed. This takes time even at 15 hours a day. If you would like to order 100 to 1000 rotors I can move it forward otherwise its a Christmas job for me.
We missed our window of oportunity earlier this year, so this is the next one..:)
https://www.sau.com.au/forums/topic/5677-disc-rotors/page/2/#findComment-90371
I'm very interested in new Skyline rotor developments. Kangaroo paw style rotors are what I'd mostly be interested in, but I can't decide if I'd want slotted or not (depends on the pads I upgrade to I guess).
Steve, is the DBA website updated often? The last time I went there a few weeks ago, I couldn't find anything other than standard rotors for Skylines. Maybe I just wasn't looking hard enough, is there a direct link to new models of Skyline rotors?
https://www.sau.com.au/forums/topic/5677-disc-rotors/page/2/#findComment-90466
I too are looking for a rotor upgrade in around 3mths time. Im sure what i currently have (standard rotors just recently machined) are fine for my driving (10km stints of start/stop) but in that 1 case that i do need to brake heavily i want to know that my gear can handle it.
No idea about any of this stuff, when i recently got new bendix pads on the back i was looking at those yellow dba slotted and cross-drilled fitted for about $1,400 or something ridiculous.
Anyway thats my story.
https://www.sau.com.au/forums/topic/5677-disc-rotors/page/2/#findComment-90509
I get in trouble for this all the time.:P
Because I use these forums to get information on upcoming projects you guys know about new products before marketing. We are still working on the GTS series so additions will be made over the next few months. We did the GTR first because of overseas demand. I know a link has been set up for a Skyline specific page on the website but I don't believe the information has been compiled yet. If you go to the WRX page you'll see the format we will use.
whether or not to go with slotted rotors depends on the type of driving you do.
https://www.sau.com.au/forums/topic/5677-disc-rotors/page/2/#findComment-90533
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
