Hello all.
I was just wondering what the go is with the octane of fuel. I want to high flow my turbo down the track but when I mentioned to my mechanic that the stock turbo can put out 13psi he said that you need special fuel at that level of boost.
As the best fuel I can buy (and do buy) is premium I asked him about octane boosters. He said they were no good.
Does that mean I just can't put high levels of boost into my car? I checked the other octane booster threads but they didn't help.
My mates WRX runs 18-20psi on premium with no additives. I wan't my Stag to drag him off.
Any info would be much appreciated.
https://www.sau.com.au/forums/topic/56797-octane-boosters/
Hi Zane, boost is pretty much irrelevant, we run 1.4 bar on Optimax all day every day, the tuning enables that. The race car runs 1.6 bar, also on Optimax. It's all down to the tuning, if your mechanic can't tune your car to run 13psi on Optimax/Ultimate/S8000 then I suggest you find another mechanic.:)
https://www.sau.com.au/forums/topic/56797-octane-boosters/#findComment-1098700
  • 1 month later...
Why don't you just get premium fuel and ad some octane booster? I have used the 3 point one before, you can really feel it even though it was the lowest one.
As I mentioned before though my mechanic said octane boosters were no good.
https://www.sau.com.au/forums/topic/56797-octane-boosters/#findComment-1166099
Hi
I ahve been using Octane Boosters for years, firstly because it was hard to get fuel where I was and then as I used to get it really cheap.. Now I use it as I am in the same situation, only get premium and I live in teh middle of nowhere so I don't trust the fuel..
I have tried most of them, some with good results, some with shocking results.. I now exclusively use "Nulon Pro Strength" sure it is a little more pricey than most, but it is the best in my opinion and it works well too..
Check this link, it is from the Nitrous Formula website where they compare some leading brand Octane Boosters, they say their product is as good as Nulon Pro Strength, but I don't believe it is.. I stick with what I know works well.. KMart have good prices, but Coventry's in bulk is good if you get a discount like I do as a Rio Tinto Employee..
http://members.westnet.com.au/yorik/octane...e-shootout.jpeg
Also another thing to consider is that from time to time Dyno Dynamics Dyno shops do delas where with every power run you do, you get a free bottle of Nulon Pro Strength, now most tuners will correctly recommend good fuel over an octane booster, but if they are going to recomend one, they will recomend the best.. If you are like me, you take what you can get..
Another good octane booster is Toluene, for about $35 you get about 4 Litres, this stuff has a RON of 130 and an effective MON of 122, so it is quite good fi you want to run extra pounds or advance.. In the days of Turbo F1 cars, they ran on practically 85% Toluene, do a search n the effects of Toluene on the web, you'll be surprised at how good it is.. I have used it for drag runs before to get extra pounds, but I also hit the FMIC of that car with a CO2 extinguisher and had Water/Meth injection too, was fun...
https://www.sau.com.au/forums/topic/56797-octane-boosters/#findComment-1166230
So whats the deal with the warning on the Nulon Pro then, about ignition timing.  Somebody wana explain? :P
My opinion, in order to get the benefit (from the increased octane) Nulon are saying that you may have to advance the ignition timing. The "warning" is "don't ring us and complain if you haven't tried advancing the ignition timing". You could also interpret it as "just adding this into your fuel tank doesn't mean you will get a power increase".
While I am doing this post I might as well give you my 20 cents worth on octane boosters. I have no doubt that if I add an octane booster it will increase the octane rating of the fuel. That's a chemical test and easy to verify. But (there is always a but) that doesn't mean my car is going use that increase in octane rating ie; produce more power. Since my car is tuned perfectly (no, I didn't tune it) to run on Optimax, then is is very unlikely that I will get even 1 horsepower increase from simply sticking some octane booster in the tank. Yes, I have tried it and on more than one car.
Maybe if the car is tuned badly, already pings for example, I might get a power increase. The current tune has to be too far advanced, too much boost and too lean for the fuel the car is currently running, and that combination is not common in the Skylines that I have seen. They are generally exactly the opposite, too retarded and too rich.
In order to get more power I have to retune it, spend a couple of hundred dollars, a bit more ignition timing here, a bit less fuel there, maybe a bit of extra boost etc etc. The result, I have completely different ignition and fuel maps to take advantage of the octane booster. The best power increase I have seen was 18 rwkw out of a pretty highly tuned engine, not bad. But (yes, another one) that means I have to run octane booster ALL of the time, otherwise it pings its head off and feels a bit flat in certain rpm/load ranges. This is not good for engine life.
So what happens if I run out of octane booster? What happens if I forget to add it? What happens if someone else fills up the car? What happens if the shop runs out? What happens if they discontinue it? What happens if they change (improve) the formula? Do I have to carry my lapt top with me all the time to upload the non octane booster maps?
Bottom line for me is, I get the best out of the fuel I can easily buy pretty much everywhere. I stick a bottle of octane booster in the boot when going on a trip just in case I have to buy some other fuel. Although even that is becoming redundant these days.
Hope that makes sense:cheers:
https://www.sau.com.au/forums/topic/56797-octane-boosters/#findComment-1171337
I might aswell pipe in here again too..
I only run Octane Booster to make up for the fact that I beliece the fuel where I live is Sh*t.. I can only get Premium unleaded and because most poeple here are tight arses I think it may have expired it's shelf life the time it ends up in my tank. I add the best Octane Bosoter I can find, Nulon Pro Strength, not only for the Octane increase and the added security it gives me, I do it because it also has some nice lubricants and other additives that clean the engine.. If I rana tank of premium and check the plugs, all black, run it with Nulon Pro, nice and golden..
My car was tuned on Premium, I just like to add security to my engines. I do go over the top in this, with larger sumps, oil coolers, rocker arm stoppers, good oil, larger radiators, but I would rather be safe than sorry.,.
Bottom line, you want the gain the extra power out of a good Octane Booster, add a psi or two to your boost, but be reasonable and wairy, don't go adding 6 psi, that would probably be too much.. If you change nothing, you'll get no better results, probably just a cleaner, smoother running engine..
https://www.sau.com.au/forums/topic/56797-octane-boosters/#findComment-1175006
  • 4 years later...
I added half a bottle of the nulon pro yesterday to about 30L of 98 point premium in my 34 GTT, and today the revs climbed about 20-30% quicker than usual.. :)
https://www.sau.com.au/forums/topic/56797-octane-boosters/#findComment-4625802
  • 3 weeks later...
All respect SK but don't the Japanese factory ECU's in the RBs have fuel maps for the 100RON fuel used over there?
In an "untuned" RB (factory ECU) I thought that running a decent octane booster with 98RON local fuel would have benefits
i.e. running the octane that the ECU is mapped for... even more so to avoid detonation with increased boost levels + hot weather?
Clearly it's a different story if your aftermarket or factory ECU is remapped for 98RON
https://www.sau.com.au/forums/topic/56797-octane-boosters/#findComment-4665216
    • Wanted to add some of my R33 GTST  R34 GTR wheels, 18x9 ET30 with 255/35/R18 PS4S'   BBS RE-V7 029 18x9.5 ET22 with 255/35/R18 PS4S' Needs a bit of camber
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
