Ha Amaru,
Glad to hear someone else benefit from cam tuning as i'm got great results for advancing exhaust and inlet (10deg adv inlet ,8deg adv exh) exhaust is very similar to yours can i ask did you try the inlet adv?
pete(someone might actual believe me know NOT):rolleyes:
Hi pnblight
It was taken back to 0/0 and we tried going the opposite way (retarding inlet, advancing exhaust) to see what happened, and it started running better.
Will try advancing the inlet cam again to see what difference makes.
:rolleyes:
Just to add to the thread a bit more.
I just had a tune on my old bunky with the tomei cams. Got rid of the breakdown issue ala plug change and gapped to 0.7mm.
Cam timing wise we tried a couple of settings ultimately settled on 4deg & 8 deg retard . The tune was nice and conservative on fuel and igntion to allow the very old motor to avoid too much stress. The boost was onyl 10/11 psi or 0.8 bar. Both my AFM's need a good clean as there is a nice difference between them reading wise on idle.
Does anyone have the lift@TDC figures for the poncams? or the full timing figures/lobe centrelines?
I just thought it might be worth checking that the advance/retard on the cams is actually from where they are supposed to be zeroed.
Also, what are the symptoms of one leaking wastegate on a twin turbo setup?
Pretty sure the lift and duration specs are on the Tomei website, accessed through the Hi Octane Racing site if neccessary.
proengines,
I think you will find no one just 'slaps' cams in. Didn't you properly measure your cam install?
You can spend quite some time altering the cam timing to yeild different power characteristics. Different turbo's / boost etc. all affect the relationship with cam timing and power curve.
Quoted from TOMEI.JP
So as PONCAM, the best duration timing and the valve lifts are decided from torque characteristic and acceleration data that is based on huge numbers of tests both on the bench actual running. You'll get the best valve timing without any adjustment but just a replacement of the factory camshaft with PONCAM.
The cams are ground totally different to factory specs, quite possibly (total assumption) with some retardation on the exhaust side. So, by advancing it 8 degrees, you basically would be returning it closer to factory spec.
It's still amazing how one can settle on 8 degree advance and someone else on 8 degree retard, when according to the manufacturer they should be pretty close without any adjustment.
Mine are going to go in sometime next year, can't wait now.
rev210,
Very nice curve.
The black line, being your second run, was it with no or minimal adjustment...?
Was your first run before the cam change...? If yes, can you post that up as well...?
Cheers.
proengines,
rev210,
I didn't install the cams at all. Why I wanted the cam specs is so the cam timing can be checked, it's a bit awkward to do without knowing what the cam specs are.
Why I wanted lift@TDC is so it can be checked accurately without dismantling too much of the car to fit a degree wheel to the crank. It's easy to find true TDC with a dead stop and check the lift against that. It's much quicker and dead accurate, if you have more than the specified lift@TDC you retard the cam, less than specified you advance it.
By the way, I think that you will find that most people who fit cams do just "slap them in" as they dont have the facilities to check the cam position.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
