josh303 Posted November 25, 2004 Share Posted November 25, 2004 hey, Im getting a new diff center in my car, i'v gotto change ratio to 3.9:1 and i didn't want to use the same crappy single spinner center. it's going to be $680 for gears (pinion & crown wheel) and i wont get any change out of $1500 to change to an LSD. so i was thinking about going to a detroit locker as they can stand about 600 horse's, wont wear out and unlock around the corners. Just wondering if anyone has had any experience with these diffs and roughly how much it cost them?? Cheers Josh Link to comment https://www.sau.com.au/forums/topic/56898-detroit-locker/ Share on other sites More sharing options...
josh303 Posted November 25, 2004 Author Share Posted November 25, 2004 bump Link to comment https://www.sau.com.au/forums/topic/56898-detroit-locker/#findComment-1100714 Share on other sites More sharing options...
timbar32 Posted November 25, 2004 Share Posted November 25, 2004 My mate had a mini-spool in his vl w/rb20. Nice launches, but chewed tyres if you ever need to corner lol... and don't even try high speed cornering....Cops didn't like it either, but if he told them it wasn't welded, they'd usually let him go. Link to comment https://www.sau.com.au/forums/topic/56898-detroit-locker/#findComment-1100778 Share on other sites More sharing options...
Cizza Posted November 25, 2004 Share Posted November 25, 2004 Mini spool's are ****ed... Parking is annoying, car feels so cheap whilst twitching about.. Link to comment https://www.sau.com.au/forums/topic/56898-detroit-locker/#findComment-1100803 Share on other sites More sharing options...
dangerous_daveo Posted November 25, 2004 Share Posted November 25, 2004 I thought detrots were locked under power? So going round a corner they would lock up if powering in/out of it??? I have a 2way, and I know every time I move my foot off the go pedel it turns better, quite bad at times. Link to comment https://www.sau.com.au/forums/topic/56898-detroit-locker/#findComment-1100864 Share on other sites More sharing options...
Cizza Posted November 25, 2004 Share Posted November 25, 2004 Yeah, detroit lockers aren't the same as minispools I was referring to minispools. All the lockers i've seen have been on v8's, and they light em' up on launch Link to comment https://www.sau.com.au/forums/topic/56898-detroit-locker/#findComment-1100995 Share on other sites More sharing options...
HypeR33 Posted November 25, 2004 Share Posted November 25, 2004 I have a locked diff in my 33. They are great for lighting up, and only have a problem on very light throttle, or part cluch turns, like car parks, or 3 point turns. Other than that I have no problem with mine. Although the twitching on those tight cornering is annoying, it really is a give and take. Good for performance. Had no problems with chewing the tyres...but that was probably because it has that much camber all round, that I had to replace the tyres before it became a problem. Link to comment https://www.sau.com.au/forums/topic/56898-detroit-locker/#findComment-1101202 Share on other sites More sharing options...
REDFC Posted November 25, 2004 Share Posted November 25, 2004 Detroir lockers are only used for drifting/Drag Racing. They create understeer. Get a 1-way LSD with heavy duty clutches (?? i think ?? ) They are best all rounder and can hold upto 500bhp. Link to comment https://www.sau.com.au/forums/topic/56898-detroit-locker/#findComment-1101205 Share on other sites More sharing options...
race_snooze Posted November 25, 2004 Share Posted November 25, 2004 Ok i have to comment I have a 2 piece rachet locker in my r33 with 200rwkw, I have no understeer as someone else has said earlier (not having a go at anyone) the only prob with them is the noise of them when there is no load and turing they clunck, they are also not cheap. They also have a bit of a tendecy to scrub out the tyres. All and all yes they are best suited to high HP and race tracks. Link to comment https://www.sau.com.au/forums/topic/56898-detroit-locker/#findComment-1101232 Share on other sites More sharing options...
josh303 Posted December 3, 2004 Author Share Posted December 3, 2004 thanks guys, i think im gunna put the detroit locker in it, just have to find some axles then i'l be on the way, why not put the best in it straight away then forget about the diff? i wont mind about the noise as long as the wheels keep going around! cheers Josh Link to comment https://www.sau.com.au/forums/topic/56898-detroit-locker/#findComment-1110632 Share on other sites More sharing options...
browny Posted December 4, 2004 Share Posted December 4, 2004 Have you looked into the KAAZ centre? Link to comment https://www.sau.com.au/forums/topic/56898-detroit-locker/#findComment-1110699 Share on other sites More sharing options...
dangerous_daveo Posted December 4, 2004 Share Posted December 4, 2004 Have you looked into the KAAZ centre? For a VL? Link to comment https://www.sau.com.au/forums/topic/56898-detroit-locker/#findComment-1111288 Share on other sites More sharing options...
browny Posted December 5, 2004 Share Posted December 5, 2004 I've seen 1.5 way KAAZ centres listed for the BW78 series diff as found in commodores VL-VS. Although i'm not sure whether the 25 spline diffs found in some of the VL range are compatible. Link to comment https://www.sau.com.au/forums/topic/56898-detroit-locker/#findComment-1111593 Share on other sites More sharing options...
daler32 Posted December 5, 2004 Share Posted December 5, 2004 i just bought my r32 on thursday n its got sum sort of a locker diff in it im curious to know tho its only locked sometimes like wen i got power on thru corners is this normal for the 32 diff or is it sumthin else?? anyone know? Link to comment https://www.sau.com.au/forums/topic/56898-detroit-locker/#findComment-1111823 Share on other sites More sharing options...
RiverSide Posted December 5, 2004 Share Posted December 5, 2004 You will know pretty quick if it is a welded diff........a mechanical diff will clunk etc. and mech won't skip the tyres when slowly going around a sweeping corner....welded diff wil as there is NO "give" in it at all. Link to comment https://www.sau.com.au/forums/topic/56898-detroit-locker/#findComment-1111909 Share on other sites More sharing options...
