Hi guys
My mrs is going to start driving my car, & shes only a P Plater, with a very heavy foot!
im going to install a 2 way boost switch hidden so i only know where it is..
Im running 14psi now, but when boost switch is installed, wots the lowest psi setting you can go!
cause she sticks in ea gear to redline, & i cry, & i tell her to back down, she tells me to shut up!!!
if i set 4/5psi, & shes thinkking y does n't the car go any faster, will she *** nething up???
u can set boost as low as teh factor wastegate will let u which is like 0.4bar 5psi-6psi
I run that on my ebc, cuz im cheap and fuel is too much and no engine damage i hit her to limited everyday :D
p.s my gf is too scaried to drive my car skyline so its all good :)
i agree with dropping the rev limit. i do this if ever i take my car somewhere for something
but if u dont want her driving it hard all the time lay down the law... its either ur way or no way.
dont let her drive it, dont be so whipped or u will be sorry when either ur car blows up or u lose the car or her.
or else yes rev limit her to 3 grand and see what she can do with that :D
Man i would tell that bitch to walk. If I was nice enough to let her drive my skyline (which i would never do anyway especially on her P's) and i tell her to ease off, and she told me to shut up.....she would never see the driver side of my car again....and she'd be lucky if she saw the passenger side.
She must be hot if you put up with this. Personally i'd put the love of my skyline first!!!
But honestly, thats really rude of her, and i think you need to stand up for yourself and your car.
Hey guys, lol...
Thanks for all your replies & help..
Yes she is gorgeous, & does ALOT for me, shes hard to pass up when she lets me do/buy anything etc...but when it comes to the 25det, being pushed to its limits after alot of my hard earned money has been put into it, & the thought of her writing it off, STILL BEING ON HER L'S, & about to go get HER P'S, it freaks me out!
Ill install a 2 way psi switch on 5psi, & set rev limiter too, cheers boys!
Hey guys, lol...
not tough enough dude. She might be hot but shes no skyline!! :wassup: my gf knows that she comes second (and for some reason still stays with me :( )
ON HER L'S AND YOU EVEN LET HER TOUCH THE STEERING WHEEL??? You're a brave man.
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
