Guest JPD Baraba
hey guys
i am a member of sdu and i have been for a while
i joined on the tail end of a good era when like mined people who loved their cars especialy skylines used to just meet up and hang out. we would help each other out through previous experiances.
then something happend. i am not sure exactly when or why but the club execs changed and so did the direction of the club. at this point there were over 200 members. 18 months later there is only 80 or so. it was attempted to run the club like a business and this is where i belive it failed. people lost the passion for the club. but you guys are right someone wanted to make this the best and biggest club in NZ and they failed.
i joined cause i liked the idea of a skyline community and i love tinkering with cars.
i personaly have joined another club not because of spite but because i wanted to expand my horizons and like i said i just love cars.
i can see why people tried to clean up the forums because they are the public face of SDU and that face was getting put through mud.
i personaly hope that the club can change back to its rots and be an enthusiasts club. this is hard because there is a lot of work that needs to be done and usualy it is volunteer work and nobody seems to want to do it.
i also hope that immature shit stirrers grow up and learn to respect other and their property.
Danijel
https://www.sau.com.au/forums/topic/57-sdu/
And you are posting that here because??? :?
I'm assuming this is Bizkit, dude we have nothing against individual people at SDU but we Aussies feel a bit jipped that we had more forum members and still couldn't join the club.
I think you'll find just by looking at the size of the Aus Forum, we aren't all red-neck mullet wearing yobbos and we have valid information to give out. But we are also social people hence the reason, I think so anyway, why the "big split" happened.
You can keep your 'information source", if I need something I'll know where to look, but don't come here feeling sorry for SDU.
BUT if you are here to have fun be merry come on in!
https://www.sau.com.au/forums/topic/57-sdu/#findComment-1392
hmmm don't know what to say. but seems like some ppl got greedy. so they took the general forum away. you can do that stuff here :)
i don't see the problem. there where rulez they weren't followed so they enforced them. u gotta live with the consequences of your actions.
i'm ready for u squizz blast away.
https://www.sau.com.au/forums/topic/57-sdu/#findComment-1405
Aussies feel a bit jipped that we had more forum members and still couldn't join the club. [/quote:0ecac8e569]
I don't feel jipped Squizz. Why would I want to join a club whose rules are not accepted in Aus. Unless all you wanted was to join so you can receive a T-shirt and a sticker.
Me, I want more out of a club. Like racetrack meets for eg. No way will CAMS let you set rubber on a track because you are a member of a club that's overseas. (at least I think not :? )
Oh and ummm, re-read Bizkit's post. I don't think he was sympathising, just stating the obvious.
https://www.sau.com.au/forums/topic/57-sdu/#findComment-1406
  • 2 years later...
    • Biggest thing is you're okay!   It sounds like between the accident, and the drive home, it was a pretty torturous trip again! On the bright side, you took the opportunity to enjoy the event more from the perspective of a spectator, than as an entrant!   Sad to see so much damage to the car. It really has taken a HUGE hit in the front end. If/when you choose to repair, hopefully the rails are straight (At least from shock tower backwards). Hopefully the extra cage coming through there has save most of the chassis rails, and HOPEFULLY saved the motor too. Best of luck when you eventually get motivated to start pulling it down to check it all out
    • Sounds more like what Brad said, that it's mainly transfer. What pad bed in procedure did you use, and did you replace/machine the rotors, or just swap pads?
    • The stutter is almost entirely in the pedal. I don't feel the brakes release and reapply as you would with ABS engaging but the pedal feels that way, without the brakes releasing. It only lasts for less than a second and the pedal is fine again. It's hard to explain, sorry.  I'll get under this weekend and just double check everything is tight. Fluid is at max where I left it.
    • What bedding in procedure did you use?   When you say stutter, what exactly do you mean? Like it feels like someone letting go of the brakes momentarily and regrabbing them again to get you to stop? Re-reading your post, and that is what it kind of makes me think you're explaining, like theres a little bit of a jolt, likely just as you're reaching a stop. I've only had this issue once. And if its caused by what caused mine, you will want to get the car up on stands again and check it over. Mine was a case of a caliper mounting bolt coming out and letting the caliper rotate on the other remaining bolt and gave play in a wheel as it came to a stop. But not every stop either!
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - then entered a hotlap with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
