Hi All,
SELLING ON BEHALF OF A FRIEND
I have a set of 18 x 8(Front) and 18 x 9(Rear) Hijoin Deep Dish Wheels.
They have come off his R33 Skyline.
The tyres will need replacing as they are worn out.
Also the two front wheels have minor scratches around the edges but the back wheels are fine.
The rear rims have more dish than the fronts.
I have attached pictures of the wheels together and one picture of the wheel with the worst scratches.
The order of the wheels in the picture attached is as follows:
front, rear, front, rear.
CIMG2122.jpg[/img]
CIMG2129.jpg[/img]
PRICE: $800 ono
Located in Sydney and prefer Sydney buyer.
Please leave a PM or call 0439 044 075 (myself) or 0417 404 237 (owner of the wheels)
Cheers
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
