hey guys, ive got my adj castor rods sitting here and im sure that ud have to get a wheel alignment when fitting them on. figured id kill two birds with the one stone by replacing whatever front bushes that can be replaced with new ones and having the wheel alignment only done once. does anyone know if theres any kits outthere like whiteline. does this sound like a good way to go about it?
cheers
https://www.sau.com.au/forums/topic/57249-front-end-bush-replacement-kits/
i was in the group buy as well for the KTS rods and already got whiteline camber kit for the front of my car. just give whiteline a call on www.whiteline.com.au and they will match the bushes to your car. Will deliver to your doorstep as well via express post. was planning on going cusco but like you said, it cost too much and illegal as well.
"illegal" i like the sound of that:D
sweet, yeah i think this is the same avenue that im gonna go too with the whiteline camber kit. are you running a rear camber kit already?? do u think there will be any issues with running just the front camber kit only?? by the way, what grease are u gonna use?? i was thinking using some top grade marine grease for the castor rods.
yeah.. apparently any form of aftermarket replacement of the arms is classified any illegal :rofl:
i have got whiteline camber kit for the front and rear of my car. Had to get an extra sets for the rears in order to correct my camber (was sitting at 2.8 degrees :rofl:)
as for the KTS rods, John (UAS) recommend NOT using any form of lubricant or grease. He made a post about it in the group buy thread so i just going to leave it raw :rofl:
"For those installing themselves use never seize grease or some sort of lubricant or grease on the thread as they are dissimilar metals and can become locked from corrosion." quoted from john.
is this what your talking about? do u mean to leaving it raw as in where the ball is? from what i can make of it he reccomends to use grease on the thread and nuts. doesnt say anything about the ball joint so i guess u dont need to lubricate that then??
...do u mean to leaving it raw as in where the ball is?..
haha... that sounded abit wrong :rofl:
but yeah.. a mate of mine just installed his cusco casters and the joints are similar to the KTS ones... i will check with him and let you know again. Another person to ask will be our SAU guru - SK :love:
Well if you wanted to replace bushes that get worn then you'd do the upper control arm bushes and the lower control arm bushes as well. (apart from caster). Whiteline sell the bits needed and if you look around on their site Skylines (apart from the 34) are supported rather well.
You might as well get a new front Whiteline adj. swaybar while you're at it :D
Hi guys, decent spherical bearings come with grease nipples (or provision for nipples to be screwed in). This is so you can lubricate them from the inside out. This achieves 2 things, firstly it obviously lubricates the joint. But more importantly, it pushes out any contaminents (dust, dirt, worn bearing metal etc) from inside the bearing itself. Think of how a main bearing works in an engine, it is lubricated from the inside out for exactly the same reasons.
Decent sphericals also come with covers and/or seals that stop the dirt, dust etc from getting in there in the first place.
Personally I would NEVER buy sphericals that don't have grease nipples and dust covers/seals and that's for a race car. I don't believe in using sphericals on road cars, they knock something fierce and wear out very quickly
Hope that helps:cheers:
bugger me!! now im worried as to how long these will last cause they didnt come with any dust boots or grease nipples. i might just have to wrap em in plastic:D maybe i should have gone for those adj bushes instead...hmmm.
by the way, how much castor can u have?? i just got mine installed yesterday and i have the urge to dial some more.
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
