Hi all,
I have noticed lately that my boost gauge is reading about 15 VAC at idle when it has been on 18 every since i installed it (approx 8 months ago). Just wondering if the heat can cause this or could i have a leak. It drops down to about 12 with the aircon on.
https://www.sau.com.au/forums/topic/57295-vac-reading-lower-than-normal/
No idea about that mine flutters occasionally ever so slightly (when idling)- do you get that as well?
Mine does not move when just idling. I might check the hoses on the weekend. Does anyone know if the air temperature of the day can affect this?
