Does anyone live near here?
The shop i am interested in is
Ride 4
1 Marriott Way
Nerang, QLD 4211
Australia
Its a motorbike shop.
If anyone lives near here or would be driving past could ya pop in and check what aftermarket parts they have available for a honda CRF 70cc engine.
They dont seem to have a website so i cant really check out what they have to offer.
If anyone can help it will be greatly appreciated!!
https://www.sau.com.au/forums/topic/57348-nerang-qld-4211/
i used to work there 2 days a week, until last week..
its only 15 mins away though from my place, I could drop in over the weekend possibly. What info are you after? see what engines and stuff they have?
You worked at the actual shop??
I was put onto them by a supplier in America that manufacturers performance parts for the Honda CRF 70cc 4 stroke engine.
http://www.bbrmotorsports.com/Products/Products.htm
The engine in my mid size pocket bike is the same as the Honda CRF 70cc engine.
http://www.skylinesaustralia.com/forums/at...achmentid=26441
http://www.skylinesaustralia.com/forums/at...achmentid=26442
http://www.skylinesaustralia.com/forums/at...achmentid=26443
http://www.skylinesaustralia.com/forums/at...achmentid=26444
Gordo if you could check what air filter/carb kits/exhaust systems and other aftermarket mods they have with rough prices it will be good as the bike i got is new to the aus market so not many places have the parts for them.
https://www.sau.com.au/forums/topic/57348-nerang-qld-4211/#findComment-1106874
I gotta check up melbourne area for some parts also, but the scene is new here so not much around.
What bike have you got?
I got a kwaka 250 ninja
I've really only got into bikes in the last couple of months, so i dont know a great deal about them apart from what ive done by pulling mine apart into a million pieces :)
pocket bikes are cool, urs looks good
have u tried calling this place? i noticed u didnt put a number with the address.....i had a quick look on yellowpages and couldnt find em but...
On the yellowpages map i looked up the address and it looks like a residential area, as i bought my skyline a couple of streets away from this place..... all the bike shops in nerang are on the other side of the highway where its the business district...........going out on a limb this place might be a home business....
But yeh i suggest calling them first
https://www.sau.com.au/forums/topic/57348-nerang-qld-4211/#findComment-1107199
I will check if i can find the number tomrrow.
I was given details from cpmany in america, so who knows if this shop even still exists
https://www.sau.com.au/forums/topic/57348-nerang-qld-4211/#findComment-1107207
I'm with MJ on this one... Address sounds a bit wierd...
But I'll be doing the bike shop run around in Nerang on Friday so I'll ask some questions for you then if you like... There is a road in Nerang with about 6 or 7 different bike shops on it... Lawrence Drive IIRC...
I just bought my bike today... :D
Kwaka 250 as well... But 1 billion times better than MJ's :)
jk Matt...
https://www.sau.com.au/forums/topic/57348-nerang-qld-4211/#findComment-1107263
Kwaka 250 as well...  But 1 billion times better than MJ's :P
jk Matt...
was that bike advertised on a bike forum? It looks familiar
https://www.sau.com.au/forums/topic/57348-nerang-qld-4211/#findComment-1107689
