#######ENGINE SOLD#######
FOR SALE
RB26 ENGINE
HKS 88MM FORGED PISTONS
HKS CON RODS
HKS STEP 2 280 CAMSHAFTS
HKS CAM GEARS
HKS 1.6MM HEADGASKET
HKS OIL PUMP
TOMEI SUMP BAFFLE
PORTED HEAD
NISMO BEARINGS
NISMO CAMBELT
AUTRONIC SMC AND LOOM
1000CC INJECTORS
HKS FUEL RAIL
MALPASSI FUEL REG
SPLITFIRE COIL PACKS
GARRET BALL BEARING TURBO(NEW)
TRUST EXH MANIFOLD AND GATE
CURRENTLY MAKING 417KW@THE WHEELS AT 23PSI
WAS MAKING OVER 500KW WITH PREVIOUSLY FITTED HKS T51R
EVERYTHING INCLUDED TO FIT THIS INTO GTR
ULTRA RELIABLE, DOESNT MISS A BEAT.
10,000KMS ONLY
PACKAGE COST TO BUILD IN EXCESS OF $35000
$22000 OR $17000 IF SUPPLIED WITH ANOTHER GOOD RUNNING RB26 AS TRADE
PACKAGE IS COMPLETE WITH AIRFILTER ETC.
(WHY SPEND $10K DOING A 300KW UPGRADE ON A GTR, WHEN FOR $17K YOU COULD HAVE A BUILT ENGINE AND OVER 400KW@THE WHEELS).
OTHER ITEMS AVAILBLE TO PURCHASER OF THIS ENGINE AT ADDITIONAL COST
NISMO TWIN PLATE CLUTCH
HKS INTERCOOLER
FUEL SYSTEM
HKS OIL COOLER KIT
TRUST EXHAUST
ARC ALLOY RADIATOR
ARC OIL CATCH TANK
HKS EVC4
(THESE ITEMS WILL BE OFFERED TO PURCHASER AT A SUBSTANCIAL DISCOUNT)
[B]AT THIS STAGE PLEASE NO ENQUIRIES FOR PARTS, PARTS WILL ONLY BE SOLD IF THE ENGINE IS SOLD) [/b]
MAY ALSO CONSIDER TRADING THIS CAR FOR A STOCKISH R33GTR+CASH
http://www.carsales.com.au/pls/carsales/!c...rch_distance=25
How do you know that these are the actual internals in this engine?Did you build it and have reciepts or is this imported as is and your guessing ??
Dude, it's genuine.. this engine is from GT51R, an R33 GTR originally from Perth which produced 647 horsepower at all four wheels with the T51R SPL turbo.. Check out the specs on X-Speed http://www.xspeed.com.au/ssport/41gtr/
Nathan traded in GT51R with Ultimate Performance Imports here in Melbourne for an R32 GTR wide body which he's also sold now.... and got himself a BMW M3 :D
The engine/performance mods done on GT51R in Perth were not done very well by the people who worked on the car over there, and it needed alot of work to fix up their mistakes.
Swweeet car though :)
  • 1 month later...
ENGINE SOLD, CAR NOW AVAILBLE IN SEMI STOCK FORM
$39,950
250kw@the wheels.
Hks cam gears,
heavy duty clutch,
apexi filters,
Trust front pipes,
hks exhaust,
c”s short shifter,
R34gtr steering wheel,
Hks turbo timer,
Hks hiper adjustable suspension,
Worx equip 18 x 10 wheels with falken tyres,
Gracer front bumper,
Trial sideskirts,
Nismo clear front and side indicators,
Nismo pillar trims,
Nismo spoiler end plates,
Top secret style carbonfibre bonnet,
Ganador sports mirrors,
Tinted windows,
Alarm system,
cd player,
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
    • And if you have to drill the oil block, then just drill it for 1/4" and tap it BSP and get a 1/8 to 1/4 BSP bush. The Nissan sender will go straight in and the bush will suit the newly tapped hole. And it will be real strong, to boot.
    • No it doesn't. It just needs an ezy-out to pull that broken bit of alloy out of the hole and presto chango - it will be back to being a 1/8" hole tapped NPT. as per @MBS206 recco. That would be for making what you had in alloy, in steel. If you wanted to do just that instead of remote mounting like @Duncan and I have been pushing. A steel fitting would be unbreakable (compared to that tragically skinny little alloy adapter). But remote mounting would almost certainly be 10x better. Small engineering shops abound all over the place. A lathe and 10 minutes of time = 2x six packs.
