R34 GTR colour name or code
Thanks Rezz, I knew you would come through with the goods. What do you think about my R32 GTR this colour with clear indicators and bronze Nismo LM GT-4 rims??
I think it'd look awesome... I love R32s with non-R32 factory colours, and with the LM GT4s it'll look see-you-perb :P
This is Midnight Purple III:
http://www.nissan.co.jp/GT-R/9901GT-RFC/MIDNIGHT_P3/
I don't have the paint code, but as this Nissan Global press release says HERE, Midnight Purple III is just like II except the colours have been strengthened further to make it more vibrant.
Thanks Rezz :D Legend. So what is the paint code for all three Midnight purples? I want the one that has more blue in it. I will probably have to get them mixed and spray tested before deciding. Now, can you get me the paint mixing recipes translated? :P
The R33 GT-R Midnight Purple has been done quite a few times before, it still looks good, but I suppose something a bit more unique like II or III would be good.
Midnight Purple - #LP2
Midnight Purple II - #LV4
Midnight Purple III - don't know :P
Heres the PDF file: http://dupont.co.jp/dupont-refinish/color/.../nissan/lv4.pdf
I don't really know what I'm translating, but if you know paint code recipies then stuff like "binder", "balancer" and "flop controller" might make sense to you...
1st Part (Colour base):
*from top to bottom on the extreme left*
Skyline
Black H.S.
Binder
2nd Part (Pearl Base):
*top to bottom on the extreme left*
Skyline
Chrome Illusion
Flop Controller
Jet Black
Violet
Violet Pearl
Binder
Balancer
3rd Part (Colour Base):
Skyline
Black H.S.
Binder
Balancer
4th Part (Pearl Base):
Skyline
Chrome Illusion
Flop Controller
Jet Black
Violet
Violet Pearl
Binder
Balancer
Note: At the top of the 3rd column across from the left on each of the parts it says "1L Combination Amount".
Now if you can make heads or tails of that that'd be great, because I'd hate to think that I've wasted my time.
    • I don't know for sure, but I'd expect them all to be interchangeable given the diff end and hub end don't move/change between any C34 series. Often Nissan will change part numbers and the aftermarket follows those year ranges; but the original part number change doesn't mean other parts won't fit. The change could be a change in material, internal parts or even just supplier. For example, all the RB gearbox to engine bolts are no longer available and there is a new part number instead. The only change is they went from cadmium plated bolts to zinc plated due to the issues manufacturing with Cadmium. They look different but work the same.
    • One year is a bit concerning. Did you try contacting GSP? It says 5 year warranty on the box if I remember correctly. I'm also running their driveshafts on my S2 Stagea.   You could check the part numbers on Amayama for your year. Here's the link for my 1998 which gives the 39100-23U60 part number. Well, that and 39100-23U70. https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/stagea/wgnc34/6649-rb25det/trans/391 What does it say for yours?
    • I ordered a GSP Front R/H Axle from here - https://justjap.com/products/gsp-premium-front-driveshaft-r-h-nissan-r32-r33-r34-skyline-gtr-stagea-4wd#description It lasted around a year before one of the boots blew out. I'm lowered, but I have GKTech roll center adjusters. One year seems a little premature. I think I'm going to spend the extra money on an OEM cv axle this time. This website - https://tfaspeed.com/collections/nissan-stagea-wgnc34-x-four-parts/products/nissan-stagea-awc34-260rs-rb26-right-front-axle-drive-assembly Makes it sound like the readily available OEM CV axle will only fit 11.1999 Stagea and up (mine is a 2.1997 S1). The JustJap listing didn't mention any years or anything for the GSP axle. Amayama shows '11.1999' and up as well for that part number. As well as 'plastic boot type'. See attached picture. So I guess my question is, does that axle (39100-23U60) really only fit S2 Stagea? It's the front driver side. If it does, I'd love to buy that instead of rolling the dice on another GSP. I've found that OEM one cheaper here: https://www.partsfornissans.com/oem-parts/nismo-jdm-r32-r33-r34-skyline-gtr-r32-gts4-right-front-axle-3910023u60 and here https://www.nissanparts.cc/oem-parts/nismo-shaft-ft-drive-3910023u60 Just a little confused because the JapSpeed listing for the GSP front driver axle doesn't mention any specific years or anything and it fit my S1 Stagea fine. So will 39100-23U60 fit my S1 Stagea even though technically it says '11.1999' and up? What would have changed? Thanks.
    • Thanks for the info. The only "Issue" I've had with the shifter is I always found the throw between 4th and 6th gear too close. I'm always worried to shift into 4th accidently and sending my motor to the moon. Adam LZ recently came out with a video and stated Serialnine revised their shifters to correct this and will change all the revised parts for 150$. Strangely enough, I contacted Serialnine right after and they denied it and said it's bullshit. I found that strange as he's a distributer. I'll keep this forum post updated on that saga.
    • Yep that is correct. It allows you to adjust the short throw range from what I can tell
