OK, I'm beginning to think this must be impossible, and I'm gonna feel like an idiot when someone explains it, but I still have the 3 and a half full 2ltr milk bottle with my old engine oil in em, sitting in the garage.
I unscrewed the sump plug on my R32 RB20 (its in an Aus R31 if that matters), drained the oil into a bucket, then poured it into 2ltr milk bottles, filling 3 of them and half filling one. As I've been doing some searching, it seems like 4-4.5 ltrs is the maximum amount you would put into a RB20, but this equates to 7 ltrs.
I'm thinking aftermarket sump maybe? Doesn't look anything special, just black, but I simply can't think of what else is could be. Could the RB20 be overfilled by such a large amount and not crap itself?
Any help would be great as I'm going to be replacing the oil tomorrow and need to know if I need to get another 5ltr bottle...
https://www.sau.com.au/forums/topic/57421-changing-oil-lots-came-out-7ltrs/
could be one of three things
1, aftermarket large sump
2, the last time it was serviced it was over filled
3, you have leaking injector and its filling your sump with fuel
I would suggest you change the oil, keep an eye on it and after 5000kms drain it and take a sample, sample kits are available from most oil companys or oil analyisis companys. The test will tell you alot about what is happening in your engine, they cost around $30
ASHLY
if it was overful it would blow the seals on the engine n prob lots of other things
do u have an oil cooler? that will usually add a few litres of oil to the system
otherwise just put in how much u think it needs, turn it over, check the level and add the amount required as shown on the dipstick
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
