I've got a great condition genuine Hybrid FMIC for sale. Has the hybrid stamp on top and hybrid sprayed onto the front of it. Mounting points top and bottom, no fin damage, the end tanks have a few small markings but could probably be polished out.
$350 firm, too big for the 1.3L project we had.
In brisbane, 0401 669 900
cheers
Jayson
Pics to follow shortly.
https://www.sau.com.au/forums/topic/57609-fshybrid-fmic-350/
sorry guys, size of core is 600X300X76
Shane, the cooler has two mounts on the top, and two on the bottom, they have a threaded hole which a 'L' shaped bracket could be mounted to easily. I will have pics up for you guys tomorrow, just a bit busy with all the xmas parties etc so im about to head out tonight, i'll have time to put pics up tomorrow.
For the mean time, this is the exact cooler, except this one is new. Mine is exactly the same...
*image removed*
pics of the actual cooler tomorrow.
cheers
Jays
Shane, no brackets come with the cooler. The two mounts on the top, and two on the bottom, have a thread inside them, so basically you would using something like a 'L' shaped bracket, one bolted into your rad support or reo bar, the other onto the cooler. Your welcome to come have a look at the cooler.
Pics of the actual cooler...........
d40d.jpg?phGQlsBBzUvWbLm8
pic 2
pic3
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
