Hi Guys
i have a R32 GTS-T RB20DET with 91,000 on the clock.
I’m in the middle of deicing to work the RB20 head or buy a RB25 head and work that with a RB30 bottom end. The RB20 is like brand new and it goes hard for the age of the car. I’m going to go all out on the engine I have a big budget,
Help me deiced which head to use, if I end up going with the RB25 ill be selling the RB20 complete with 91,000 on the clock
https://www.sau.com.au/forums/topic/57691-big-rebuild-help-needed/
dont mess with anything on the rb20, sell it and get a 26 as others said and with 17psi, high flow turbos, 700cc inj, mine made 350rwhp only revvin to 7100rpm still pulling hard! thats 118mph and 12.0 at drags in a vl too (mph is low 11s)
i have had a rb30et engine and it is like a truck engine, slow, doesnt like to rev, and also had a rb25, which aint nuthin compared to the 26 so thats my 2c worth.
26 is like a reliable rotory i reckon, they just love to scream and rev :D
best engine by far (my opinion)
Unless you were going to keep the RB26DETT relatively stock (.9bar of boost 240rwkw) I wouldn't bother with it as you are going to spend $$ on injectors/turbo and possibly cams anyway.
I would spend the money on a RB25DET with some nice internals & head work.
My thinking is for ~$6000 you can get a decent RB25DET built up that's head will flow more than the stock rb26dett head + it will be a fresh motor with a known zero thrash history.
All things being equal (turbo's etc) the RB26 has very very little over the rb25, cam specs is basically all it has. This can easily be fixed. :D
There is no point comparing a RB30ET to a RB30DET or RB25/26DET. They display completely different traits. The SOHC being a slow narrow rpm power band rev'r.
From a legal point of view I would go with the RB25DET.
If you want to build up a nice motor and don't want to shell out for a R33 RB25DET front cut I would look at the R32 RB25DE motor.
Rebuild the head with a mild port/polish & inlet/exhaust valve deshroud.
RB25DET 8.5:1 Forged pistons (9:1 if you are going to run bigger cams)
Shotpeened Rods or if you can spend the extra 1k over shotpeened rods on forged rods by all means do it.
Blueprint & Balance
There you will have a reliable 350rwkw stormer, if you have the forged rods say hello to 400+rwkw. :)
Honestly I think much over 300rwkw using an RB25 begins to lag a little too much for the street, this is where I would consider the bigger 3ltr.
The 3ltr apparently has issues with rods bending at around 550ft-lb. So if you balance out the torque x rpm using turbo sizing boost & rpm then you will have a motor that will hold together.
500ft-lb x 7000rpm / 5252 = 666hp on stock rods.
You need to keep tabs on the amount of torque and the motor will be fine.
In theory :D
The SOHC is good and proven but to get anywhere near the flow levels of the DOHC head it needs to run some seriously large cams that return bad drivability and fuel economy.
I've posted this previously but just to note it appears the R32 RB25DE head has the same sized valves as the RB26DETT head. Being 35mm on the inlet and 29.5mm on the exhaust.
The R33 RB25DET head appears to run 34.5mm on the inlet and 29mm on the exhaust.
I've done a few measurements lately and this appears true.
I would like to see more heads or hear from others that have access to heads to let me know if it isn't just a couple of freak heads I've measured.
BUT the R32 RB25DE ports are slightly smaller than the R33 RB25DET & RB26DETT heads. The RB25DET & Rb26DETT ports share the same design and size.
When you look at the valves of a RB20DET (30mm inlet & 27mm exhaust) they really do look like little baby toy valves next to the Rb25/26's.
There's an old saying - There's no replacement for displacement.
The RB30DET really needs cams to unleash its top end power as it essentially flowing the same amount of air at a much lower rpm over the rb25 & 26.
Obviously. :D
yea that sounds about rite cubes" i will go with the RB25DET head and the RB30 Botton end so it will be a RB30DET.
ill be doin
Rebuild the head with a port/polish & inlet.
Forged pistons
Big high spec cams
Blueprint & Balance the RB30 block
HKS GT30/40 turbo or HKS T51 turbo
Motech M600 ecu.
Nismo 1000cc injetors
bosch high pressure fuel pump
how much will a new RB25DET head compelet cost?
If you are going for that sort of setup just go straight for the RB26 head. It has solid lifters meaning that you can run much higher lift cams. A wider range of cam specs are available, and you get a better inlet manifold arrangement then that used by the RB25 head.
Also if you want to run the T51, it has a v-ban exhaust manifold, again more readily available for the RB26 head.
yes.. Do check out how much you can get a RB26DETT head for as they are much cheaper now than when I did my setup.
If you go for a greedy plenum or use the stock rb26dett inletmanifold/plenum you won't have to lower the engine ~13-15mm.
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
