Youve probably wired it wrong,
Check that you have wired it into the light switch.
Sometime you can accidentlly use the wire that switches the deck dimmer on (with the headlights) as an earth.
Be sure to earth straight to a metal part of the chasis.
As I recommend to everyone who is having a car stereo problem,
check the wiring, then double check it and then triple check it.
Then if all that fails. get soome one else to check it.
https://www.sau.com.au/forums/topic/5774-jvc-kd-s785/#findComment-90514
I have just installed my 785 today and found that if you do not earth to the vehicle you will blow numerous fuses...not good.
When you turn it on is every thing reset back to normal? Like volume, track number etc.. I f so check that you have the power and continuous power in the right connections.
Mine works fine and was great value for money...
https://www.sau.com.au/forums/topic/5774-jvc-kd-s785/#findComment-96878
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
