Hi all,
I have Rays Volk AV3 rims and I want to take them apart to paint the inside spoke section. They have 24 hex head bolts holding them together, is it as simple as taking these off and prising the two sections apart. Will they buckle, will they go back together easily? Just hoping someone may have had a crack at this before.
https://www.sau.com.au/forums/topic/57782-taking-apart-two-piece-rims/
ive taken my old ssr rims( silver rim + black spokes) apart to repaint them. didnt take me long to take em apart but took me ages to figure out how to get em back together again. what i did was take all the bolts out then on the inside use a hammer and this blunt flat ended piece of metal i found to use in the same way as a chissel. first u start at one point and knock it 2-3 times then slowly work your way around the rim knocking it out 1-2mm every time. eventually it'll just pop out. the hard bit is putting it back in. after an hr or so of trying to mallot it back in the same way i poped it out, i went to the local bolts store and got me 6 of the same bolts but twice as long. then i realigned the center piece and put all the nuts back in. the centre piece will not sit flat but on an angle cause its slightly lager than the hole itself cause its a tollerance fit. u use the 6 or so longer bolts and place it on the end thats highest. now the trick is to pre tighted all the nuts then slowly go around and tighten each nut about 1 turn (the longer ones 2-3 turns to catch up) and keep on doing it until the centre piece fits into the wheel. then its a matter of tightening it all up. hope that helps. i still havent gotten around to respraying my rears. will do that over the holidays:D:D have fun.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
