first yr there, same old same old? hmmm:confused:
it was my first yr there too..quite good really, the bass really hit me hard, goddamn my throat hurts
absolutely loved the r34 gtr on the dyno run....the one up for sale from autostyle....summin like 3 metre high fumes were coming out of the exhaust
took plenty of pics with girls in em:P
i liked the ambulance babe, nurse cadence.....woohoo
cant wait til nxt autosalon show
https://www.sau.com.au/forums/topic/57816-autosalon/#findComment-1112103
The 34 had some detonation issues up high in the rpm but reeled off an impressive number.
Nice car by the way 2BNVS.My car is similar to yours in the bodykit dept also went to jetspeed.
Trust front bar,400r side,nismo rear pods vented bonnet with front scoop (i noticed that you have the one without the front scoop) & 3d fiberglass wing.
Nothing is final on my ride as of yet i hope to be at an auto-salon somtime in the near future to.
There really was allot of cars there with scissor doors there though wasnt there.I loved the glossy candy red on cars or any candy for that matter it really looks the shit when complemented with a good set of rims and bodykit.
There was also a hatchback WRX there with a blue stainless steel looking flek paint job (DREMPT) damn fine.
A great day out will be going again (car nut) :boinkcar: :D
https://www.sau.com.au/forums/topic/57816-autosalon/#findComment-1115454
oh yer nice stuff, yer i thought the extra scoop at the front was a bit much for my taste but still look good though...
DREMPT with the front mount not connected to anything but a neon behind the core...
shoud get a fake quad turbo engine made up and take my bonnet off...lol...
cheers... ben...
https://www.sau.com.au/forums/topic/57816-autosalon/#findComment-1115465
cheers... ben...
Really is that true.he did not have it hooked up.just a wanna b turbo then hay..I was hanging with shift performance on saturday right next to filo34's stand.
https://www.sau.com.au/forums/topic/57816-autosalon/#findComment-1115534
I flew all the way from Perth just for the event!!
Ok Ummm what the hell is with the use of cotton wool balls around the tyres.. that "baggin" it up effect is soooooooo old :-(
besides that though it wasn't... well too bad... I like the MR2 "D CUP" fat wide body and mags.
Is the Ketzal Strilings "FLYEN" by any chance? couple of nice cherry red skylines and a couple with gulll wing doors! I liked the Osmans Rex that is extreme the amount of money and $$$ on that thing!! O plus how hot is the Koeniggsig
https://www.sau.com.au/forums/topic/57816-autosalon/#findComment-1115577
I took a heap of pics at the event.. they are all here....
http://www.bassdistribution.com.au/images/fb04
I too flew accross from perth specifically for the event and then a weeks R & R so just got back... but show was a awesome, some things not to every1s taste but def gave me a few ideas!!..
altho I must say that if you are going to do scissor doors... get decent 1s as all the 1s at the show that I saw had the doors so damn low down it wasnt funny... makes getting in and out of the car extremely hard.... you need to get them just about verticle to work properly... there are kits out there to do it but they do cost a hell of a lot more!!
cheers
https://www.sau.com.au/forums/topic/57816-autosalon/#findComment-1119956
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
