Just posting this to inform you all that theres a new workshop opened up at Yatala called "Proline Automotive".
The guys are holding an open day this Saturday 11th December 2004 to introduce themselves and the business. The workshop and facilities will be open for people to inspect, the boys there to have a yarn to and the BBQ fired up to satisfy those hunger pains.
The address is:
3/118 Lahrs Road
Yatala QLD
Phone:
55407900
If you would like to phone the boys, contact either Lindsay, Clint or Scott on the number above.
https://www.sau.com.au/forums/topic/57926-new-workshop-opening-at-yatala/
They will be into performance and imports plus the everday car servicing. The two mechanics that are working there are very experienced in working on skylines inparticular.
They don't have a dyno at the moment but are looking into one next year sometime.
So Mister Nizmech, if that is your real name, heres a problem for you:
Recently reassembled engine running rich on 1 cylinder. Plenty of fuel, plenty of spark, timing ok, good compression.
Would you:
(a) Have a smoke,
(B) Buy a pie from the lunch lady,
© Read the paper,
or
(d) Check the plenum / inlet manifold for a misplaced rag which has now jammed up number 1 runner and is stopping air from reaching the cylinder
I'll tell you what WE did. All of the above. In that order.
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
