Hi,
I have a GTR power FC which will not save it's values. You can change the value eg idle RPM & the Idle revs don't seem to change. Also after you turn off the ignition (& back on) the value you set it to is back to the previous setting.
My car is an R33 GTS4 with RB26DETT, it's running fine from a standard R33 GTR ECU.
Things I have tried:
Checked all power & earth connection to the ECU as per nissan wiring diagram - OK
Tried another PFC with my hand controller in my car - has the same problem
Yet to try:
My PFC in another car
Another Hand Controler with My PFC
My deduction so far is that it is either the car's wiring or the Hand Control...
Can any body help, or know of a good workshop who could help to sort this out.
Thanks in advance.
https://www.sau.com.au/forums/topic/58003-gtr-power-fc-experts-wanted/
Hi,
Checked all power & earth connection to the ECU - OK
Yet to try:
Thanks in advance.
Probabley locked by Excel tuner... find a Datalogit owner and they can unlock it for you... It won't cost over $1000.
Oh, you say two different PFC's do the same thing? Well thats a different story.
Will it accept a change to the ignition or fuel map?
TT
Thanks Tom, I think it was you who suggest before it may be locked.
I took it to croydon & had Jim check it out, he said when it's locked that you cannot even access the fuel map menu etc.
Mine is all there, it just won't save. :(
Hi,
Yet to try:
Thanks in advance.
You have to save the changes, have a look at the Commander Manual it shows you the steps.:)
I'm pretty sure I'm saving the settings as per the manual, Jim from Croydon Autosports also confirmed that the values are not being saved. He blamed the wiring.
Tomorrow I will try swapping HC & PFC into a known working GTR & see what I can work out.
S/N of PFC PFC-RB26-9605-0349
S/N of HC FCC-NT9605-0366
I'm guessing that the "9605" means that they should be matched.
You'll find it is the wiring in the vehicle to the ECU that is the problem....
A couple of the pinouts require permanent power and then there is a shutdown sequence where the ign switch power is shut off to certain pinout and then the ECU then saves settings and turns itself off. Any change in this power down sequence,(different wiring, alarms, immobilisers)wil cause the symptoms you describe.
Similiar to pulling the plug on a windows based PC rather than shutting it down correctly....
cheers.
RPMGTR, looks like you are correct.
I tried my PFC&Commander in a real GTR today, Thanks to NVDAGTR :P , & it worked fine :(
I noted all of the pins on the ECU which had power, now I can test this in my car & hopefully find the variance....
It's strange how the factory ECU works without whatever is different!
LOL... How many times have I heard that before...?
The difference with the stock ECU is that, it doesn't have to save any changes, as it's not programmable.
AFAIK, there is no save function with the commander, it applies the changes as soon as you change any parameter. The changes are saved when the ignition is turned off, which explains your problem.
Is the GTS4 wiring same as the GTR wiring...?
Would I be having this problem if it was???
I was just hoping that if people had heard of this problem or experienced it so many times they could say something like "yes, pin XX needs contant power for the data to be saved".
Hopefully I can sort it on the weekend & post the results here for future reference.
According to this site (click), most of the Nissan ECUs share the same pinouts.
Your problem is that RB26 transplants in an R33 GTS4 is not very common, give SDU a try as well. Different models of skylines are more prominent there.
Good luck on the weekend.
The Weekend has been a success :wassup:
Pin 16 & the ECCS relay power supply turned out to be the culprits
You don't know how long I have been trying to solve this.... very frustrating :)
Attached are my finding for all those who have this problem in the future.
Thanks again to NVDAGTR for letting my try my PFC in his car :)
just had a response from the Datalogit forum from an SR20 punter who had experienced the same problem!!!
Do you have a wiing diagram - or the rest of the one above. I have'nt seen one so clear before.
TT
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
    • Off the back of feedback we have decided to mix up this next Motorkhana at Avalon to have some targeted skills practice for beginners to advanced. Saturday 6th September 2025 8:30am Capped 26 entries Standard Entry Fee: $89 Members Entry Fee: $55 (SAU Victoria Only) Entries Close: Friday 5th February  Where: 55 beach road Avalon. https://maps.app.goo.gl/HNUE3EuNue3sJxh38 Entries: Limited to 26 entrants (Passengers allowed over the age of 14 with a signed disclaimer and same safety gear) Disclaimer: Download  Please electronically sign and email to [email protected] or print and hand in and Driver Sign In. To compete in this event you will require A valid  AASA General Speed licence or (Day license via the AASA Website for $50) MA Licenses are no longer accepted by AASA https://aasa.com.au/  A helmet, long sleeve clothing and a 1KG mounted fire extinguisher recommended (But not Mandatory). Further details within Supp Regs on the enty link. Entry Link > https://www.sauvic.com.au/entry/deca/20250906 You can bring and have a passenger in the car but they need to comply to the same safety and clothing as driver. Bring your car and get to battle others, win, lose or draw. I can guarantee you will have lots of fun. Any questions email [email protected] Entry List: 1.Anna S 2. Luke S 3. Jesse Givens-Lamb 4. Luca Stamatescu 5. Madeleine Stamatescu
    • Wanna rewrite all of that in, say, 2 or 3 separate sentences, so that we can read it?
