bore: 85mm
stroke: 83mm
Bearing sizes and bearings are the same as a RB30. The rods would be no use in a performance engine as they run a huge piston pin, 26-27mm-ish from memory and the rod is way too heavy.
The crank is forged steel, not sure about snout/flywheel pattern. It would be top quality being a diesel as they are under a lot more load than a petrol engine, diesels also usually have larger radiuses on the journals although the RD28 might have fillet radiuses but i'm not sure on that.
The head gasket is very similar to an RB30, the bolt pattern is the same, I use the same plate to pressure test both. The RD28 uses a MLS head gasket which might be worth having a look at to use on an RB, it's available in 1.42, 1.5 and 1.58mm to set piston to head clearance on the diesel engine.
Thats about all I can tell you without having one here to look at.
https://www.sau.com.au/forums/topic/58134-rd28-diesel/#findComment-1116296
  • 1 year later...
Can anyone tell me if the RD28 block is the same deck height as the RB30 ? Also was it cast thicker in the bores allowing larger rebores or did it use liners . Curious to know if more than 3L can be had without huge cost for same external dimensions .
Cheers A .
https://www.sau.com.au/forums/topic/58134-rd28-diesel/#findComment-1821688
I would assume(Going on the knowledge of the engines we have at work) That it being a diesel would have a much thicker block to cope with the greater compression ratio and heat produced.. I imagine that would help with boring it out to a greater capacity...
https://www.sau.com.au/forums/topic/58134-rd28-diesel/#findComment-1821966
very interesting - have you been in a car witht eh engine.
my old man has one in his 2000kg patrol. stock standard this thing pulls from 2000rpm (full boost by 2100rpm along with max torque) redline is at 4600rpm !!!
interested to know what its limits are and how much power you can get out of it
about 96kw 250nm torque - standard not interecooled
https://www.sau.com.au/forums/topic/58134-rd28-diesel/#findComment-1822661
We had a good long look at one of these about 5 years ago, there were some reasons it got rejected as a possibility..........mmmmm........they don't have block mounted oil squirters.........the crank has no provision for cam belt drive maybe......or was it oil pump drive.......hamonic balancer perhaps, not sure about main bearing cradle.
There isn't any foreseeable advantage over an RB30, the stroke was shorter (83 mm versus 85 mm) and the crank tested up much the same for hardness, same size bearings etc.
I think there is still one kicking around ther machine shop somewhere, I could always dig it out and refresh my memory.
:) cheers :D
Edited by Sydneykid
https://www.sau.com.au/forums/topic/58134-rd28-diesel/#findComment-1822669
Thanks all , I was just curious to know if the RD block would take all the RB30 internals but allow larger bore cylinders for the same external dimensions . I've not looked at an RB block for a while so I'm not sure how much meat there is between the cylinders . SK did the workshop test that one for core thickness ?
Thanks A .
Edited by discopotato03
https://www.sau.com.au/forums/topic/58134-rd28-diesel/#findComment-1824190
Thanks  A .
We didn't cut one up, since it was an N/A diesel (not a turbo) the concensus was it wouldn't have much extra meat. Plus the water jacket isn't overly large anyway. so not a lot of room to move.
:D cheers :P
https://www.sau.com.au/forums/topic/58134-rd28-diesel/#findComment-1824888
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
    • To be fair it's the other way around. 300kw is boring in a modern Golf or BMW. They are so competent / well-engineered / devoid of emotion that you have to go stupid fast to feel anything. Whereas the <300kw RB still makes all the right noises and it feels good to drive. Can pull off at the lights with the turbo whooshing and the blow-off pssshing and feel like the coolest kid on the block. Just don't look to the side where you'll see the bored housewifes in their shitbox Yaris/Corolla/Camry that kept up because you didn't go fast at all
    • 300kW is so boring in a Skyline, you'll get spanked by someone's mum's Golf with Alibaba pipes, and an email tune.
