Has anybody else had issues with afm before?
about 6months ago i was having major issues with the car idoling at 2000rpm and not reving above that when accelerating. Afm was changed after a week of testing everything and that fixed the problem, Now it seems its starting to do it again and its driving me nuts. What are the odds of having two Afm stuff up with in 6months in exactly the same way??
Can anyone help me out ? Any ideas?
thanks
tim
https://www.sau.com.au/forums/topic/58139-rb20-afms-help/
hi, check your TPS sensor plug that connects to the throttle position sensor. My car idled at 2000 rpm one day when the plug 'was left unconnected' and wouldnt accelerate cleanly. I thought something had gone majorly wrong, but once I plugged the tps plug back in all was sweet. I think the computer uses some of the other info to make an estimate on the fuel should the sensor fail, and runs a safer tuning map for the engine as a precaution.
It could also be the AFM, try cleaning the thin wire in the centre of the AFM with CRC contact cleaner, it is supposed to 'self clean' once the ignition is switched off by rapidly heating the wire to burn off any deposits, this probably isnt working so good after 10-12 yrs especially if you have an oily aftermarket air filter in there. It could also be the solder inside the square box attached to AFM, it could be dry when wires conect to the pins that the plug connects to. If you are sure that AFM is no good and are going to buy another, give it a go at repairing it, check the forums for some info. Just make sure when you are doing the soldering that you dont let too much heat get anywhere else( use heat sinks).
I did mine years ago and it is still going strong.
Stephen
https://www.sau.com.au/forums/topic/58139-rb20-afms-help/#findComment-1117005
WD40 is the worst thing you can spray it with as it will leave a residue on the wire and distort the reading. Maybe even damage the AFM. Use something like Carby clean or throttle body cleaner or for a more expensive alternative, try using that Contact crap.....never WD40 though.
https://www.sau.com.au/forums/topic/58139-rb20-afms-help/#findComment-1118148
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
