For Sale: (pics follow)
Tanabe Shocks and Springs - full set.
These are SUSTEC Damper Tanabe - Lowered and Harder than std
Came off my R33 GTS-t S1 1995 (replaced with TEIN coilovers)
Rear - TBCR33R (KYB LG29)
Front - TBCR33F (KYB LG20)
Rears a little squeaky
$320
Stereo - Nakamichi CD Play AND Naca MD Player (2 seperate units)
Came out of my R33 from Japan (comes with Band Expander)
All wiring - will not seperate as these go together
$250
Speakers:
1 set of Nakamichi 5" splits - 60W RMS
Comes with Tweeters and X overs (all Naca)
Quality Speakers
no grille
$120
1 set Rockford Fosgate 6x9" Punch - 220W
Come with/in 6x9 covered MDF boxes
no grille
$120
2 Sets of Wheel Lock nuts (18mm) to suit R33 studs $20 each
Used K&N Pod (155mm) - $15
Formuling Steering wheel and boss - came off a Camira I had ages ago - $20
email : [email protected]
https://www.sau.com.au/forums/topic/5820-fs-r33-stuff-cd-md-bit-pieces-syd/
BF,
I am interested in the Nakamichi and 6x9". I tried to give you a call but you did not pick up. I hope that you are going to give it to me for a special price.
I just have the stock stereo in the car so can only listen to AM at the moment.
Give me a call.
AD.
Louis,
The suspension sits the wheel arch just off the top of the tyres. Put it this way, it's lower than the way my TEINs are set up now, so if ya wanna see, you can judge yourself.
Getting the springs off is not as easy as removing and fitting the whole assembly. You need spring compressors and maybe an air rattle gun.
AD, I'll call you about the Naca and 6*9s
Cheers,
    • Yeah, plenty of air flow, there is a dedicated path that feeds the air in to the OEM intake tube behind the bumper As for a "tangible effect", maybe, but getting the pod/intake air out of the hot engine bay is worth it psychologically to me, even if it gives no performance difference, so the tangible effect in my Lizard brain saysss yessss  In the end, to me a tangible effect isn't always about performance, sometimes it a sound or a look, or even a...... feeling  Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
