But Roy, under boost wouldnt the extra 0.5L make a fair bit of difference, even considering the other factors? Also as you keep saying the RB20 head dont flow too much compaired to the rb25 head etc.
Some more thinking, i aint an engine builder, mechanic etc so this is just me thinking out loud, welcome others to point out shortcomings in theory:)
But the internal combustion engine is just a pump. So its all about consuming/passing cfm. A certain amount of cfm allows a certain amount of fuel to be added equating in a certain amount of bang ie power.
Basically you all know this, but as i said just thinking out loud.:rofl:
So the smaller RB20 needs more revs to pass the same cfm. Ok so where the RB25 flows 25cfm at 3,500rpm, the RB20 may need 4,250rpm. The fact is they should be both able to make the same power, admittedly at different revs.
As for the head thing, the RB25 has larger valves, i think it also has bigger cams, and dont foget it has half a point more compression. So it will always be able to flow more cfm.
That said, if your turbo only supports a certain amount of cfm, so ultimately the turbo will run out of flow, the fact that the RB20 doesnt use the air as effeciently means that to get a similar cfm it may need a bit more boost.
Now obviously if were talking 300rwks then the ability of the RB25 to flow more air probably comes into its own. I dunno, but i suspect at the sort of cfm we are talking about at 250rwkws, well i think the RB20 can still flow that sort of cfm albeit it will need a few more rpms
Yeah well my after seeing what 1GGTEs can do (toyota 2L inline 6cyl for those that dont know, came turbo and supercharged) I know of people who have made 400rwhp (no correction on the dyno on a 28* day from memory) off these stock internals, just a bit of head work all bolt ons, (quality) and a big mofo turbos. They are a square block, but I dont see why RB20s are THAT much different to the toyota version albit stronger engine, but still, thats lota ponies. (in terms of flow espceically)
Im all for the RB20. Im just up agaist it a bit more having an extra 200kgs or so than most of you lot.
Carryling less weight then the R31, R33, A31 etc also makes the RB20s life a little easier in the R32, its still a pretty heavy car though for a 2L:(
I suppose it comes down to what you want, i dont mind a bit of lag, takes me back to the Sierras/DR30/R31 Grp As:thumbsup:
Plus i love hearing engines scream and pulling big revs, and one of the sweetest things i have heard in a while was a R32 drift car the other day at Calder, the thing was singing, sounded as though it was pulling insane revs, made the SRs sound a bit average:)
Fun to drive, sound trick, cheap, reliable, and can get reasonable power out of them cheaply. Want big power then there are probably cheaper/easier ways to skin a cat.
Did i say how good the R32 drift car sounded:)
Just transplant an RB25 Roy, you know you love the response :thumbsup:
LOL...that night in your car bummed me out...for a reasonably std car it went great, compared to my laggy ho:(
But looking at your drag times im still 7/10s quicker with a slipping clutch:)
RB20 :kick: RB25
RB20 POWAH...FOREVER!!!:looney: :looney: :looney:
It has even better response now (Ex Cam Gear).
I'm waiting delivery on a new set of Splitfire Coils, i'm wanting -atleast- 5/10's out of these suckers if they fix my boost issues :thumbsup:
I'm waiting delivery on a new set of Splitfire Coils, i'm wanting -atleast- 5/10's out of these suckers if they fix my boost issues ;)
:thumbsup: My cam gears resulted in a loss of power, and worse response:( Bloody RB25 owners you lot are a protected species with all those bolt ons meaning good gains:)
Im waiting for splitfires as well, then i can go back to 1.3-1.4bar and hope the adjusted clutch does the trick...fingers crossed. Your car would still leave mine for dead though on the street:thumbsup:
It would up until about 3,000rpm after that yours is like an angry bull on roids!
You're running about 220rwkw right?
Yeh around that power level, but typical of when you start modifying cars, im not sure why sometimes the car goes like a cut snake, other times it doesnt rev out near as fast or pull near as hard. Th engine has the miss when i run over 1.0-1.1 bar, so ill fix that and i hope my engine runs more consistantly after that.
When it revs nicely the thing feels way quicker then when i picked it up from the tuner. It just doesnt seem to always want to run like that. Im going to hook a channel of my data logger up to my fuel rail as well, and see if a fluctuating rail pressure has anything to do with it:confused:
Though im scared there is still a problem with my PFC, as it was reading funny ignition values a month or two ago before it got re-tuned. And looking at the position of the crank angle sensor, well im not convinced the timing is where it should be:( perhaps when they tuned it they worked around the problem as they couldnt identify it:confused:
So when i get the new exhaust housing ill send it off for another tune and hopefully they can look at the timing etc as it seems strange to be clocked all the way round like it is...plus id like a 2nd go/opinion on the cam wheels hurting power and response.
Would you expect cam gears to work on an RB20 with HKS 2530, with around 210-220rwkws (bbenny) but not on an RB20 with a TD06 (me) with simialr power:confused:....:thumbsup:
Im keen to find out what the turbo goes like with the smaller housing
Hahahahahaha I feel the same and also about how there is tons of crap you R32 and R33 owners can get to just bolt on while us R31 owners need to mod shit and have no body kits and wheels that bolt on :thumbsup:
So what have most of you guys actually done?
ECU, turbo, extra fuel??? Anything else like custom manifolds to pulse the turbo more, or just stock manifold??? Any other 'crazy' stuff like that?
I've done
- R32 Silver top RB20DET
- HKS GT2535 turbo
- Stainless steel exhaust manifold
- R33 GTR injectors
- Nismo adjustable fuel regulator
- Bosch 040 fuel pump
- Z32 AFM
- Apex'I Duel Funnal pod
- Apex'I Power FC and hand controller
- R32 GTR intercooler and 2.5inch stainless piping
- GReddy Profec B boost controller.On 12psi for now
- GReddy Type S BOV
- Catch can
- Works Auto 3inch dump pipe,3inch mild steel mandral bent zorst with Bazooka muffler
and all it needs is a tune for more boost.Hoping for 300+rwhp
Good power at 4,500rpm would be nice. What sort of power are you making at 4.500,    5000,   5,500rpm,    6,000rpm etc etc
I have about 135rwkws at 4,500rpm, which is about 30-40rwkws off where i want to be.   At 5,000rpm i have just over 180rwkws...that where i want to be at 4,500rpm. So rather then get the cams im just going to get the smaller (properly sized) exhaust housing for my turbo.
I would have been better off getting a hi-flow or a 2530 tuned normally and make 210-225rwkws with better response. Or perhaps tune the car normally at 13psi to make the same power?!?!?!?!
Hi Roy, this is what mine looks like at 1.25 bar
rwkw-rpm
180 7,750
190 7,500
200 7,250
225 7,000
200 6,500
175 6,000
160 5,500
154 5,250
150 5,000
145 4,750
142 4,500
That's an average of 178 rwkw from 4,750 rpm to 7,750 rpm. How does that compare with yours?
It isn't much more than yours at 4,500 rpm, but the cams help the top end so it doesn't top over badly at 7,250 rpm which is what happens when I have standard RB20 cams in it. There is a bit of turbo selection result here, as well as cams.
I don't want to sound like I am picking on plain bearing turbos, but yours displays the same symptoms I see often. They build boost rapidly at highish rpm for their (small) size and then run out of airflow (because of this smallish size). Looking at it the other way, if you had a larger plain bearing turbo, then the boost build would be even later but you wouldn't loose as much top end. On the other hand the (larger) ball bearing turbo gives slightly better boost build, but it is still large enough to give a much better result at higher airflows (rpm).
Bottom line, it has been my experience that plain bearing turbos have a narrower power band, regardless of size. Time for some cams, toughen up that top end.:thumbsup:
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
    • So, what else.... Power. I don't know what it is making because I haven't done a post tune dyno run yet; I will when I get a chance. It was 240rwkw dead stock. Conclusion from the day....it does not need a single kw more until I sort some other stuff. It comes on so hard that I could hear the twin N1 turbos on the R32 crying, and I just can't use what it has around a tight track with the current setup. Brakes. They are perfect. Hit them hard all day and they never felt like having an issue; you can see in the video we were making ground on much lighter cars on better tyres under brakes. They are standard (red sport) calipers, standard size discs in DBA5000 2 piece, Winmax pads and Motul RBF600 fluid, all from Matty at Racebrakes Sydney. Keeping in mind the car is more powerful than my R32 and weighs 1680, he clearly knows his shit. Suspension. This is one of the first areas I need to change. It has electronically controlled dampers from factory, but everything is just way too soft for track work even on the hardest setting (it is nice when hustling on country roads though). In particular it rolls into oversteer mid corner and pitches too much under hard braking so it becomes unstable eg in the turn 1 kink I need to brake early, turn through the kink then brake again so I don't pirouette like an AE86. I need to get some decent shocks with matched springs and sway bars ASAP, even if it is just a v1 setup until I work out a proper race/rally setup later. Tyres. I am running Yoko A052 in 235/45/18 all round, because that was what I could get in approximately the right height on wheels I had in the shed (Rays/Nismo 18x8 off the old Leaf actually!). As track tyres they are pretty poor; I note GTSBoy recently posted a porker comparo video including them where they were about the same as AD09.....that is nothing like a top line track tyre. I'll start getting that sorted but realistically I should get proper sized wheels first (likely 9.5 +38 front and 11 +55 at the rear, so a custom order, and I can't rotate them like the R32), then work out what the best tyre option is. BTW on that, Targa Tas had gone to road tyres instead of semi slicks now so that is a whole other world of choices to sort. Diff. This is the other thing that urgently needs to be addressed. It left massive 1s out of the fish hook all day, even when I was trying not too (you can also hear it reving on the video, and see the RPM rising too fast compared to speed in the data). It has an open diff that Infiniti optimistically called a B-LSD for "Brake Limited Slip Diff". It does good straight line standing start 11s but it is woeful on the track. Nismo seem to make a 2 way for it.
    • Also, I logged some data from the ECU for each session (mostly oil pressures and various temps, but also speed, revs etc, can't believe I forgot accelerator position). The Ecutek data loads nicely to datazap, I got good data from sessions 2, 3 and 4: https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-2?log=0&data=7 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-3?log=0&data=6 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-4?log=0&data=6 Each session is cut into 3 files but loaded together, you can change between them in the top left. As the test sessions are mostly about the car, not me, I basically start by checking the oil pressure (good, or at least consistent all day). These have an electrically controlled oil pump which targets 25psi(!) at low load and 50 at high. I'm running a much thicker oil than recommended by nissan (they said 0w20, I'm running 10w40) so its a little higher. The main thing is that it doesn't drop too far, eg in the long left hand fish hook, or under brakes so I know I'm not getting oil surge. Good start. Then Oil and Coolant temp, plus intercooler and intake temps, like this: Keeping in mind ambient was about 5o at session 2, I'd say the oil temp is good. The coolant temp as OK but a big worry for hot days (it was getting to 110 back in Feb when it was 35o) so I need to keep addressing that. The water to air intercooler is working totally backwards where we get 5o air in the intake, squish/warm it in the turbos (unknown temp) then run it through the intercoolers which are say 65o max in this case, then the result is 20o air into the engine......the day was too atypical to draw a conclusion on that I think, in the united states of freedom they do a lot of upsizing the intercooler and heat exchanger cores to get those temps down but they were OK this time. The other interesting (but not concerning) part for me was the turbo speed vs boost graph: I circled an example from the main straight. With the tune boost peaks at around 18psi but it deliberately drops to about 14psi at redline because the turbos are tiny - they choke at high revs and just create more heat than power if you run them hard all the way. But you can also see the turbo speed at the same time; it raises from about 180,000rpm to 210,000rpm which the boost falls....imagine the turbine speed if they held 18psi to redline. The wastegates are electrically controlled so there is a heap of logic about boost target, actual boost, delta etc etc but it all seems to work well
    • hahah when youtube subscribers are faster than my updates here. Yes some vid from the day is up, here:  Note that as with all track day videos it is boring watching after the bloopers at the start.  The off was a genuine surprise to me, I've literally done a thousand laps around the place and I've never had instability there; basically it rolled into oversteer, slipped, gripped and spat me out. On the way off I mowed down one of the instructor's cones and it sat there all day looking at me with accusing cone eyes as I drove past. 1:13:20 was my fastest lap, and it was in the second session, 3rd lap.  It (or me!) got slower throughout the day as it got hotter.
