Posted for 46n2..
Does anyone know where the relay for the fuel pump is in an R32?!?!
Wiring diagram shows that between the ECU and fuel pump there is a relay and I need to know where this is asap, I think its in the fuse box, any help really appreciated.
Thanks guys...
sweet, I've been frantically looking for it everywhere. Everything I have read said it was between the ECU and the IGN. But I couldn't find any locations. The only other relay I knew of was in the boot there. Sorry to steer you astray mate.
pretty certain it' the one in the boot because i touched it while the car was running and it started to jump it's idle between 300rpm and 2000 rpm hOORAY! :rolleyes:
unplugged the relay and the terminals are corroded, so time to get a new relay.
w000t
46n2
two.06l,
I've recently done a full re-wire installation of a Wolf 3D into my R32 GTS4, utilising the factory relays. I think I know where the fuel pump relay is. I think you will find that the "relay" in the boot is the "fuel pump control modulator" (but I can't swear by that).
Guest two.06l
w000t
46n2
Good work, and good luck with the repair
:rolleyes: thanks two.06l
Blind Elk: do u know which of the 2 relays in the kick panel are which? just for future reference in case swapping out this relay doesn't fix the issue...
Going down to the servo to see if i can get a replacement today :P
46n2
Unfortunately, I wasn't smart enough to label them, or make any sort of written record as to which is which.
I think you need to get the genuine Nissan article, because they use a non-standard pin arrangement (well, they are certainly different to the Bosch types). Unless you are prepared to unpick the connectors from the plug to connect onto a standard Bosch type.
also, the relay is green, and the other green relays in the car seem to to have the same numbers moulded into the casing.
ie:
top looks like this:
3 o-o/ o-o 5
1 o-nnn-o 2 (the n's are the closest i could represent the image :rolleyes:)
46n2
ahh ok...so what am i holding? the green cased thing i'm holding has the above pic on it :confused:
also what page of the w'shop manual are you on? I'm finding it pretty hard to read through it as an electronic copy :rolleyes:
I'm guessing both relays from behind the ECU are the same PartNo - they are just a relay after all.
Ive been working from the JPNZ manual - the engine wiring diagram is on page EN-289, if that's any help
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
