Hi all - anyone have any ideas where a CD stacker could be installed in the stag?
Doesn't look like there is enough room under the front seats and sticking it under the passenger side glove box would severely restrict leg room... :P
Any ideas, thoughts, suggestions, solutions???
BTW when I looked under the front seats I noticed that both driver and passenger have wires attached - would this imply the seats are heated?
Cheers ;)
https://www.sau.com.au/forums/topic/58490-cd-stacker-placement/
  • 4 weeks later...
Wow, I like the AMP mounted inside the spare wheel bit !! I might do that with the amp for the sub ! I wonder how it goes with heat and ventilation ?
I just relocated my stacker to that pocket on the left hand side of the car (it was just bolted to the floor on the left hand side.
I mounted it as low as I could in that pocket, so the top of the stacker is at the bottom of the pocket, so I can still use all the space that the pocket had before. I just hope the Octane booster bottle doesn't leak into the stacker !!!
J
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
    • Neg, the top one is actually for the front. The sizes are 18x10.5 +18 and 18x11 +32.   I measured many times but I'm sure I'll have problems as this is the thread for problems.
