Wanted r33 Non turbo
I have a non turbo 1996 Series 2 R33 for sale;
Metallic silver
46,000km
5 speed manual
HICAS
Dual airbags
Climate Control
Alarm/immobiliser
Clarion CD Player
16" ANZ spoke rims
2.5" exhaust, 4" tip
Blitz Air Filter
Lowered springs
Tinted Windows
Immaculate inside and out
$19,500 firm
ps. your email bounced back? so im posting here.
https://www.sau.com.au/forums/topic/586-wanted-r33-non-turbo/#findComment-16082
pics and specs of r33 non turbo gts
this car can be put on the road at $16,000 registered and roadworthy, with
complianced, all done drive away
specs
car is a grade 4 where 4.5 is best possible grading at auctions
1994 model
manual
2.5 litre 6
57,300kms
sports steering wheel
aftermarket sports exhaust system
stereo-mini disk player and cd player
climate control
full electrics
tinted windows in rears
non accident vehicle
these are the pics of the car in Japan
if interested e-mail me back
this car can be done for $16,000 on the road in your name
[email protected]
https://www.sau.com.au/forums/topic/586-wanted-r33-non-turbo/#findComment-22727
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
