not going to be as close as it would have been had the "ECU Fueling" fell thru :O
might as well tell him now... i was meant to pick up a bigger turb on tuesday but the guy ended up not wanting to sell it... at the same time i was meant to pick up one from a regular here for a friend of mine who wanted one but i was going to use it after the news of mine falling thru... and he did the same!!
was going to get it for 350 :O
yeah I dont plan to drag much after this time more the drift so I thought I would try lookign for a 1.8 -1.9 60' time hoping to crack the 13's its should be doable
running stock shocks at the back pineapple the tyres.
I want to show that a basic gtst r32 can run into the 13's
should be fun.
ive decided that i wont be doing much more to my 32 other than FMIC and bigger turbo and maybe some better brakes and wheels. Basically cause i want to do up a Trueno so i can learn how to drift. Drags arent my thing i much prefer driving a car than str8line meat headedness.
    • Maybe also really stiffly sprung track cars. Get the inside wheel up in a corner and all the fun stops. Also me sometimes (rarely) when I have to stand on the brake to convince the diff to drive the wheel that is still on the ground when I'm trying to diagonally get over severe driveway entrance, etc.
    • I feel like I'm missing something. You had an authorised installer come out and install a new alarm. Post install the car doesn't start, and you aren't getting the installer back to fix what they did wrong?
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
