Hey Guys,
Lately i have been experiencing problems with my R33 GTST.
Mods are: FMIC
3in zorst
Boost to 10psi(bleed valve)
Plugs gapped to .75
(Stock bov)
I Have a problem when accelerating in the low rpm range. It seems to miss completely and jump violently when accelerating. It also stalls when idleing. It sometimes feels like someone is jaming the brakes on when driving.
I have a feeling it could be the airflow meter.
Anyone else have any suggestions????
I realy need some help because it is realy un-driveable at the moment
Any Help. PLEASE???????????
https://www.sau.com.au/forums/topic/59151-help-needed-on-jump-problem/
Hey Mate I don't have a specific recommendation for you problem, but try a search for "missfire" it is a very common problem.
Most likely are plugs and/or gaps (maybe not in your case if they are already gapped down)
Dirty Air Flow Meter
Failing/cracked coil packs
Possibly CAS or Ignitor pack
Dirty injectors
Fuel pump dying.
    • Here is a recipe. Sonic blocks till you get one that has a good enough bore. Get a torque plate and block brace, use your choice of fasteners (arp ect) bolt the thing together empty, half fill it and let it cure. Release it when it has, go to a REPUTABLE RB Builder and get the thing line bored/honed and cylinder honed to size, then wash. Once its all clean and dandy, wash and blow it out again. Then again.  Assemble said engine to your desired clearances with oil control mods, gasket to suit desired CR/Squish ect. Attach your extended sump with proper trap door oil baffles and head drain plumbed to sump with a SUMP BREATHER SYSTEM. Build your front diff with a decent LSD, rebuild your transfer case with a few extra plates, more than likely replace your tailshaft centre bearing and tighten up the rear diff. Tune to minimise excessive midrange cylinder pressure (timing unless you like to split bores and rebuild engines) Enjoy your engine, but hate the fact you are now destroying engine mounts, gearboxes, gearbox mounts, diff output flanges and driveshafts, diff mounts, tailshafts and front CV's.   Disclaimer.... Ive never done any of the aforementioned stuff.......
    • 440s will support well over 400HP on petrol, which is a decent place to be for an RB20. 230+rwkW. Will be a safer bet for idle/low load. 550s would be nice for the extra headroom. I've made the same decision with mine (Neo25). 1000s are probably too big for the Nistuned ECU, so I have some smaller ones.
    • Appreciate everything guys. I did go ahead and get an alignment... most of my complains are solved. Car is not perfect, but it's good enough. If I notice uneven tire wear or anything I'll just take everything back to stock.  Thanks again!
    • They still have not shipped the 550cc injectors as they weren't in stock, so in theory I could ask to get the 440cc ones instead, if those work better in my scenario. They're the same price so really shouldn't be an issue. Unfortunately I am not so knowledgeable in most parts of tuning so I wasn't sure what's best to choose between the two. 440cc ones are the lowest they have (not in stock, but available to buy nonetheless).
