Hey guys, anyone wishing to try some new software to interface with the consult port on your vehicle?
look here..
http://www.tangentrix.com/forums/viewforum.php?f=5
Software is called TECU, and will work with the same interface as used by CalumSult, ConZult etc...
Check it out and let me know if it works on your vehicle. :headspin:
Shane
https://www.sau.com.au/forums/topic/59221-new-consult-software-for-pc/
the pga forums (pulsar.org.au) had some guys in WA selling them. ive made a few for the interested on silviansw forums. you can find most of the stuff you need from jaycar and make it yourself if your good with electronics, have a lot of spare time and can track down a consult connector (or hard wire it)
as for the software in the original post, ill check it out soon, more free alternatives the better!
okay got a converter and tried it out last night, i felt so Fast&Furious driving around with the laptop in my car :) but some comments (please note this is the only software i've used so far):
* The user interface is rubbish and confusing.
* The ROM dump most certainly doesn't take 11 mins, after 11 mins i wasn't even 10% complete.
* The auto ECU detect worked fine for my RB20DET.
* The logging does its job, i was supprised at how often it sampled but many consecutive readings were the same at ALL variables so i kinda question if it was an update or a copy of teh previous.
* The application doesn't exit properly, after you close it it leaves a process called "Consult" running which muck you up if you open TECU again.
On the whole i think it's a promising product and above all it's free but it has a way to go yet, simple things like using check-boxes when it should be radio buttons, the UI REALLY let it down and is so important.
i also have some settings.dat error message on startup.
always happens until you run it and save-settings.
also you need to download the 1.7Mb zip at the top of the thread THEN replace the default exe with f revision exe (~400kb). I got the f by itslef and it confused teh crap outta me.
  • 1 year later...
  • 3 months later...
How hard will it be to make the cable to hook up your laptop?
Would any body have a parts list?
Ive installed a RB20 into another car with only the Engine wiring loom will i find the Consult conneter on the ECU wiring loom? if not how to you hard wire 1 in?
Thanks Damo!!!
I have a tutorial online to make the consult interface (with genuine consult connector) - based on the PLMS design.
Also have another one on how to make the connector from ATX plug (The tutorial on tangentrix is a little confusing in some parts)
DIY Connector : HERE
Consult Interface : HERE
I have the genuine (and rare) consult port connectors for sale as well if you're not confident enough that the DIY connector will do the job
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
