Tried to search for this as im sure it would have come up before, but have you ever tried typing 'tail lights' in a search on these forums?
Anyways i've noticed a couple of R33 skylines that seems to have a differnt brake light sequence to my own, just wondering if this is a modification or perhaps a standard on differnt model 33's.
My sequence involves,
Headlights on = all 4 hot plates on.
Braking = 4 hot plates on and spolier light on.
Alternative sequence,
Headlights on = 2 Outer most hotplates on.
Braking = 2 Inner most hotplates on + Spolier light.
https://www.sau.com.au/forums/topic/59323-alternative-braketail-light-sequence/
I have mine,
4 hot plates for when the lights are on
Both the outter ones for braking and the spoiler.
You dont have to be a guiness to do this. All i did was cover one of the electrodes (one is for normal light and the other is for brake. My ones have the brake one covered) of the inner lights (on the light globes) with electrical tape in order that it wont light up when you push the brakes. Thats it
You can make it as shifty as you want.
I simply cut the wire powering the inner tail light (at the tail lamp assembly). So I have:
Headlights + 2 hotplates
4 brake lights
So, at night I get 2 fresh lights come on when I brake (don't have one of those ridiculous "eye-level" brake lights).
hmmm, cut or simply put electrical tape...
i think i know which one is more practical, in a way that u can change the sequence when you like to. Instead of cutting then you decide you dont like it anymore and have to solder the wires back together...
yea its easy but ive actually gott make the effort to do it lol
forget the orange lense like i could be bothered changing it ill just leave it red
or i can make the current indicator the reverse light as well as being the indicator.
either way the problem isnt the lights its covering the hole where the old revrse lights are meant to be (either side of the number plate). i would get a genuine aussie spec rear bar but i didnt have time to order it before i painted the car and ill never be able to match the colour so im gonnahave to get some thing made up maybe out of CF or something
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
