  • Replies 122
Hitman is an awesome tuner!! He tuned my car as well, and he did an excellent job!! I did both a road tune, and a dyno tuner to touch it up! He charged a very reasonable price :D
He is on the forums.. nick is Hitman!! :cheers: I don't think he browses the site very often though... not sure if he'd respond to PMs either... probably would? His number is 0417 259 391 if you'd like to give him a call ;)
Website: http://www.hitman.hm/
I had a slight increase in fuel ecomony, but my driving style changes from day to day... lol!  it depends on how much i'm boosting per tank! :)  as for smoother response.. i got 12.9secs worth of smooth response! :)
HEYA, thats alright, and what mods are you running other than the PFC?
Power FC in my GTR was installed and tuned by C&V by the previous owner it seems not to bad of a tune but I'm not pulling very good mph at the drags for the power I have compared to other GTR's.
Price from CRD was $1200 that's including adjusting cam gears and dyno tuning time . Bel wants $350 for a road tune and it take's them a couple of hours . I've heard good stories about both shops but I've also heard a few bad stories as well so I'm not sure who to go to yet . I soppose can't go wrong with either .
SAS across the road from from CRD and near Advan is soppose to be very good also for tuning the power fc's .
should also mention unigroup who are good with Power FC's also and have installed and tuned a fair few and I've spoken to alot of people who are happy with them . Only thing is they need to use a hand controller cause they don't have the proper software like the other's.
My car was originally tuned at C&V when I bought it and the tune was OK.
Then I had it tuned by the hitman who cleaned the tune up a bit. good bang for your buck at around $300
The the PFC was tubed by CRD when the injectors and FPR were installed and the car ran even better, Highly recommend, and Jim was very helpful. Lance not so helpful you do pay for it though, It costs around $600-$700.
Spoke to one of the people that own Bel Garage today. They charge a pretty reasonable fee, and its not something thats through the roof.
What they said to me was that if you have a bigger turbo, injectors etc, then it usually cost more cause they have to configure more obviously.
Other than that, got to go make some inquiries to the so called "HITMAN" ? However just have to wait for my exhaust system to be complete before going ahead with my tune :P
Cant wait!
How long did they spend on it.. 9-5 2 days straight? I know where they (CRD) could stick $1,200.
My car hasnt been tuned by them yet but yes they did quote $1200 for tuning and adjusting cam gears. Lance said they needed the car for the day but I doubt they would be working on it all day. The tune really only needs a clean up and they would have a fair idea of what cam setting's actually work by now so yeh they are very $$ compared to the rest .
Exactly, they (and other shops) work on these similar cars everyday and know pretty much straight away what direction they should be heading in, it's not like it would be 100% guess work for every single car (even though engine to engine would vary in the same model cars) but not enough to require $1,200 worth of "labour".
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
