Go the stacked plate style like SK has. Much more efficient than a serpentine style of the same size. In fact for the same size core it works about 30% more efficiently.
MOST of the good stacked plate cores are made by the company from Canada and just rebadged/packaged. Eg. B & M, BTR, Drive tech. All the same core, different packaging but all VERY good trans coolers. It is unbelievable how much heat transfer gets done with one of these... And the oil is the only thing keeping the box alive!
Cheers.
Nice work, i recently installed a Transmission Cooler on my 2001 Nissan Maxima, after already going through one gear box and seeming there note exactly easy to find i decided to take some precautions this time, ended up being very easy to install, me and a mate had it finished within 3 hours..
Good work
  • 1 month later...
I fitted up the Davis Craig cooler yesterday. It is a relatively easy fitment but having a front mount makes it a bit harder to get in.
One thing the SK didn’t mention or maybe didn’t have trouble with on his car is that one of the stock pipes ends right next to the edge of the cooler making it impossible to fit the hose. I got around this by bending both pipes towards the front of the car a little.
oh and I have better horns
Good job on the install, must have been tricky getting to the bottom bolt on the trans cooler standard bracket with the front mount there. The standard pipes were a bit of a pain, but I squeezed the hoses on without doing any bending. Yours is neeter though with the bent pipes and you have used less hose as well.
Oh and nice horns, what brand are they? Are they loud?
PS; not keen on the pink wiring though
I have a large tranny cooler fitted to my 25x Four ( 4WD non Turbo ) Stagea as I tow a caravan. But I notice it takes ages for the box to go into torque converter lockup during normal driving. I am guessing this is because the cooler is so efficent and there is a temp sensor in the tranny?? I tried putting a board in front of the cooler when I was not towing, but not any better. Is there anyone else with an extra cooler who has noticed this too?? Bit hard on fuel this way, as does 3000rpm at 100kph till the TC locks up!
  • 3 weeks later...
  • 7 months later...
Just to let you guys know my stock cooler is about 280x160xwhatever and has been moved to the side out of the way of the radiator and intercooler.
I decided to put a temperature gauge in to see what the temps were doing. I asked an expert what temps to worry about and was told to keep it under 130 degrees C.
I then went to Wakefield on a hot day and did numerous laps. The trans fluid temp never got over 105.
The conclusion I'm drawing here is that the cooler is smaller in size but handles the job no worries. I have no idea whether more heat is generated towing or racing.
I have a tube without the fins for my power steering stock. Should I be worrying about cooling this fluid any more? For some weird reason it's on the other side of the car to the power steering fluid reservoir. Maybe because of the steering box being on that side.
Generally speaking, I reckon circuit work is better (cooler) then towing as there is lots of airflow. Towing can be lots of torque converter and gearbox load with very low airflow eg; in traffic.
I am upgrading the R32GTST power steering cooler from the standard loop of aluminium to the transmission cooler I took off the Stagea. Plenty big enough and I am being environmentally sound by recycling. :(
:( cheers :(
said this once to Chris (prank)
You loose perspective of size when you living life at 1680x1050. For me the original was "small". ive dumbed it down even furthur :D
Ill probably make the ducting out of 0.5mm or 1mm aluminium from bunnings, pop riveted together.
Ill let everyone know :(
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
