Hi there I've just hooked up an amp using the rear speaker inputs rather than RCA input.  There is a bit of hiss when volume is low.  Is this normal and will unning off RCA's help.
Thanks
Ben
Hiss, i hate that, especially when passengers notice it and go, 'whats that sound'
Anywhos... i had this problem and found that my wires running from the head unit to the amp were running with power cables. When running cables try to isolate them from other cables, esp. powered ones, as much as possible. this will minimise hiss.
Hopefully you can upgrade and employ some RCAs, and dont go cheap on the RCA's either. get some shielded ones.
If you were like me and still had a slight hiss when all was hooked up, try using a filter on the inputs at the amp end, or Run a wire from the grounding point of your amp back to the grounding point of your headunit. This worked for me.
https://www.sau.com.au/forums/topic/59489-amplifier-hiss/#findComment-1135089
Running speaker lines next to power cables will have little effect on "hiss".
Running RCA's next to power cables runs you the rish of introducing "alternator whine", which is different to "hiss".
Conclusion: Run RCA's.
https://www.sau.com.au/forums/topic/59489-amplifier-hiss/#findComment-1135259
    • Nah, turn the boost up, break the gearbox, and enjoy leaving it parked for a few years while you save for a better box...
    • I see those two Stageas have the "punched 40mm hole" deregistered Japanese number plates 👍 Nice kouki group shot with the different colours too.
    • Ended up just being a loose exhaust bolt luckily.
    • Yeah I made that post way too early, sorry I must have assumed it was bad because it's a 20+ year old thrashed shitbox lol. It was just a loose exhaust bolt.
    • Like others have said, drop the power to give your drivetrain a % of reliability until you can up the drivetrain reliability  It isn't rocket science, build power to the weakest link with a % of safety Whilst upping the the reliability of the drive train is costly, there's no point in having the engine make big power if it keeps eating the drivetrain....ask me how I know, I had the tow truck on speed dial for a few years, and I spent huge amounts of money fixing issues and breakages that really would have been cheaper in the long run if I did it right the first time Me, I like a nice sized fudge factor, that keeps me off the tow truck
